Author Topic: Come on baby don't let me down!  (Read 1860 times)
Offline eigenvector
« on: June 29, 2015, 06:53:51 PM »
 :D
Found out just how far you can ride on a 7A main fuse.  Scouting for places to do a plug chop test, and seeing how the weather was wonderful I decided to take a ride.
I was enjoying the ride, passing all the rush hour traffic going the other way, hit my signal, main blows, I coast it around the corner and onto a nice wide shoulder.
"No problem, I'll just pull out my spare....."  Whoops, my spare fuses in my OTHER jacket. :-[
So I had to use the only fuse I had available, a 7A turn signal fuse, and since my turn signals were shorted out somewhere - no loss.
I had to ride on that fuse for a LONG time, the whole while hoping that
1)  No traffic to hold me up
2)  It didn't decide to give up the ghost
Still turned out to be a nice ride, although I think I have an air leak to track down among other things.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Come on baby don't let me down!
« Reply #1 on: June 30, 2015, 03:59:48 AM »
There's always the "500 amp" fuse:
 :o :o :o
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline fmctm1sw
« Reply #2 on: June 30, 2015, 04:40:00 AM »
 :o :o :o
LMAO.  The first thing I thought was "screwdriver"    :)
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #3 on: June 30, 2015, 05:05:07 AM »
Other options:
Offline Desert-SOHC
  • It's old
« Reply #4 on: June 30, 2015, 11:14:51 AM »
A bit of solder wrapped works too and is easy to carry.  ;)
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #5 on: June 30, 2015, 11:20:32 AM »
hey Rob, its a little too warm to ride with cheese in your jacket  ;D
nice MacGyver fuse hacks.   ::)
Offline eigenvector
« Reply #6 on: June 30, 2015, 03:47:54 PM »
Last thing I need to do is stuff a wedge of cheese in my mesh jacket.  Probably hang it up once the rain starts, only to find it next year. :o
You know what, as I'm typing this I'm eyeballing a spare 6mm bolt that I had laying around - just about the right size...
Rob
1977 CB550K
1983 VF750S Sabre
Offline Rocky2010
  • Live in Strayla
« Reply #7 on: June 30, 2015, 10:54:22 PM »
All good doing the old alfoil trick if its a faulty fuse but if there is a real short there you could be setting up for a signal fire and burn that bikes wiring out. Nothing like the smell of burning wiring, its a smell you never forget  :(
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
Offline Vinhead1957
« Reply #8 on: July 01, 2015, 07:36:49 AM »
Fuse is never a problem !   It's an indicator of another bigger problem.
« Reply #9 on: July 01, 2015, 08:21:14 AM »
Mythbusters did the bullet for a fuse test. Probably not fatal but never a good idea. They really had to crank it up to make it fire. I'd consider shooting it first.
 Glad you made it home, hope it's an easy fix like a bulb filament.
Offline eigenvector
« Reply #10 on: July 01, 2015, 03:59:23 PM »
We'll see.  Haven't had a chance to take a gander, but I suspect the rear right signal is shorting against the grab bar somewhere.  Could have swore I fixed it already, but obviously not.
I wouldn't ignore a shorting problem for longer than I had to - because ultimately it's far less work to fix it than keep replacing fuses.  Finding it is the issue - it's not like water pipes where spotting the dampness is your clue.
Rob
1977 CB550K
1983 VF750S Sabre
