Author Topic: chain replacement  (Read 2564 times)
Offline joeson
  • back in the day
chain replacement
« on: October 23, 2006, 08:53:43 AM »
hello all, my 78 750k630 0ring chain is stretched. in sections it is loose and others too tight.I have cleaned and lubed with assorted penatrating oils and chain/gear oils and ultimitley was able to split the differance with modest improvment in the tension .the sprockets appear good with no noticable wear differance.Replacement of my chain is priority but is it really nessasary to replace the sprockets considering the local shop sells used sprockets with new chains as a set..for more $$ As well I have a soft link and plan to replace the chain myself you know my baby and all nobody touch.
cracka'mybackjack
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: chain replacement
« Reply #1 on: October 23, 2006, 09:03:48 AM »
Do u need to replace both sprockets and the chain in all one shot ?
Offline jalfonso
« Reply #2 on: October 23, 2006, 09:05:09 AM »
I replace everything as a set.  New chain, new sprockets.
Ride Safe.
John Alfonso
1974 CB550 Four
1982 750F Super Sport
Offline joeson
  • back in the day
« Reply #3 on: October 23, 2006, 09:08:46 AM »
I dont see why to replace my sprockets other than from what I have previuosly read here that all should be replaced as a set.. I just need to get a new chain from what I see on my bike unless I am missing something my sprockets appear good  worst case by replacing the chain only and the sprocets are worn could I not replace them later if not run too much ..Lots of rainy days lately and not much good riding weather left I will have all winter to spend time and money and not ride then
« Last Edit: October 23, 2006, 09:13:48 AM by joeson »
cracka'mybackjack
Offline Steve F
« Reply #4 on: October 23, 2006, 09:45:32 AM »
You need to explore the possible problems here.  You're assuming that the chain is at fault, but it COULD be the sprockets, although not easily visible.  Rotate the rear wheel, and make a mark some where on the rear sprocket and corresponding link when the TOP section of the chain starts to get tight. Rotate the rear wheel 360 degrees and see if the chain gets tight again.  If it does, your sprocket is out-of-round.  If not, the chain is probably stretched.  Not all sprockets are evenly hardened and may wear unevenly just enough to make a difference.
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: October 23, 2006, 09:50:33 AM »
One option to consider here is converting to a 530 chain and sprockets.  Costs much less and is at least as strong as the old 630 chains.
Offline joeson
  • back in the day
« Reply #6 on: October 23, 2006, 10:14:07 AM »
I will use the advice here and make sure before throwing good money after bad. Thanks for the replies.Time to park the bike for the season as much work is needed other than this to be ready for my next journey safely
                                 joe
cracka'mybackjack
Offline siter81
  • vintage bike junkie!
  • TOO MANY BIKES? NEVER
« Reply #7 on: October 23, 2006, 02:44:36 PM »
I would replace both sprockets if you are going to replace the chain.I have run 530 o ring on both my suzuki and k5 with no problems
My 2 cents.
Siter81
61 BMW R27 70 BMW R75/5  75 RD350
71 SUZUKI T500
75 CB750K5  Weisco 836, WEB CAM.DYNA IGN,KERKER,K&N,TAYLOR,GALFER,AGM ETC.
 01 HONDA VC11000C3 AERO.
74&75 DUCATI 860 GT'S
Offline tramp
« Reply #8 on: October 23, 2006, 02:49:10 PM »
just replaced my 630 chain this year
if your sprockets are good just do your chain
 my chain was old and dirty with stiff spots too
now its smooth as silk
1974 750k
Offline Loudpipe
  • Broken Vehicle Collector
« Reply #9 on: October 23, 2006, 04:27:02 PM »
If your sprockets have NO visable wear on them, they are OK.  If the teeth are chipped or worn at all, they need to go as a set.  No sense in buying a new chain to have it eaten up by beat up sprockets.
- LP
1974 Honda CB350F
Previous: 1978 Honda CB750F, 1971 Honda CB500K, 2009 Yamaha YZF-R1
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #10 on: October 23, 2006, 04:32:04 PM »
Replace the chain and the sprockets as a set, always.
Think about getting one of these:  http://www.scottoiler.com/sol_kit_universal.asp
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline Loudpipe
« Reply #11 on: October 23, 2006, 04:36:36 PM »
What exactly is that, and how does it work?
- LP
1974 Honda CB350F
RyanLilly
« Reply #12 on: October 23, 2006, 04:48:01 PM »
Why do many people like the scottoiler so much? Don't out bikes already have an auto-chain oiler from the cranckcase oil? at least my K4 does, it seems redundant to add a second oiler, but Ive never used one, so I cannot judge the merit of this product, I would just like to propses this question to those who have.
Offline ic455
  • 750 K6
    • My Gallery
« Reply #13 on: October 23, 2006, 06:09:45 PM »
never used a scottoiler myself, just good old chain wax.  For a laugh, my boss uses white lithium spray on his Shadow's chain.  I know it could probably be argued that white lithium is great, similar to chain wax or other chain lubes, etc.  BUT I have used white lithium (spray and otherwise) in many different applications and found that it's great; if you don't want it to stay for a long time.  It'll stay forever, say on the outside of a hood hinge or inside a door jamb, but in between moving parts it just doesn't seem to want to 'stick around' HAHA  I figure if it won't lubricate a door hinge on a car longer than 2 weeks, it can't do much on a motorcycle chain.
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #14 on: October 23, 2006, 07:11:16 PM »
OK my 2 cents  the auto chain oiler in my opinion and many others was a  blind buck     bad eye deer  lol little humor anyway I dont want motor oil on my chain for the most part it wont stay I use a cobo sometimes oil wax sometomes PJ 1 the stuff that STICKS and I allways put it on with the chain warm right after a ride now as far as the tight loose I this late in the season would put just a chain on IF you want to stay with the 630 if you want to go with 530 O ring of coarse you gotta change all thats what I would do is convert to the 530 Oring and the Oring is the key good luck seven fifty four ever  Craig up here in deer country Maine
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
Offline nickjtc
« Reply #15 on: October 23, 2006, 07:27:11 PM »
At risk of, whatever, let's just say that this discussion has been around and gone around several times over the last few months! ::)! ::) Being the great fan of the KISS principle that I am, I like the automatic chain lubrication idea because apart from keeping the reservoir topped up, it is one thing less to have to think about. And the chain needs less adjustment.
1977 Suzuki GS750
Offline dpen
« Reply #16 on: October 24, 2006, 05:13:04 AM »
Simple equation
replace chain = replace sprockets (always)
Offline nteek754
« Reply #17 on: October 24, 2006, 02:26:43 PM »
Hey all I run a 530 Oring chain and hadnt had the new set  sprockets and chain on my 73 750K for very long  maybe few thousand miles and  all of a sudden I had that  tight loose tight loose  well I replaced just the chain and let me see its been  well 6000 mile this past summer and 8000 last summer and  oh who know how many  3 summers ago but you should get my point  there was nothing wrong with my sprockets (in this particular case) glad I didnt hang them up in the garage good luck with what ever you do with your issue seven fifty four ever  Craig in Maine
Offline Loudpipe
« Reply #18 on: October 25, 2006, 08:18:23 AM »
People go a little overboard with the fanaticism of replacing both chain and sprockets at the same time.  It's just like cam/lifters in an engine.  If one is visibly torn up or worn badly, they both MUST be replaced at the same time, or they will eat each other up very quickly.  However, if you can't detect any wear, there is no reason to replace the unworn part.
- LP
1974 Honda CB350F
Offline joeson
  • back in the day
« Reply #19 on: October 25, 2006, 11:32:50 PM »
My sprockets out of round I hadn't thought of that ..I will sure check out  all the best
cracka'mybackjack
