Author Topic: 76 cb550 clear tube test fuel level?  (Read 2643 times)
Offline kippstakes
« on: July 01, 2015, 09:09:04 AM »
My bike, a 76 cb550k, seems to be running rich on cyl 3 (fouled plug/stumbling), so I decided to get my floats evened out with a clear tube test.
I have read that the carb bowl fuel level should be 3-4mm below the flange. Is this correct? When I ran the test the fuel level was consistently even with the flange (except for cyl 3, which was above it by a few mm). The test was done on perfectly level carbs.
Are my floats just a bit wonky and need some tweaking, or is my measurement info wrong?
Thank you
Strength is just an accident arising from the weakness of others.
-J. Conrad
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: 76 cb550 clear tube test fuel level?
« Reply #1 on: July 01, 2015, 09:13:49 AM »
#3 is definitely too high so while you have to carbs off to readjust that you might as well check the others. The others might be a tad high but you're close. Mine were always 1-2mm below the lip of the bowl. You might recheck the the float measurement as described in FAQs on this board.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #2 on: July 01, 2015, 10:15:58 AM »
aftermarket float valves usually throw things off a bit.
spot on!
Offline turkey4me
  • The closer you are the less you can see!
« Reply #3 on: July 01, 2015, 11:20:45 AM »
Where can we source the brass fitting that mounts to fuel bowl?
« Reply #4 on: July 01, 2015, 11:33:18 AM »
If you have PD carbs, put the tube on the overflow pipe,
If you dont have PD carbs, push/twist the tube into the overflow screw hole, or, a brass fitting can be made to screw in, or get a PVC hose fitting with the same OD as your drain screw, taper it a bit, and screw it in the hole
The thread pitch might also match a brass vacuum sync fitting
« Last Edit: August 05, 2016, 06:54:30 AM by flybox1 »
Offline kippstakes
« Reply #5 on: July 01, 2015, 04:49:05 PM »
Thank you for the replies.
Flybox that's just what I was looking for. Perfect.
My tool to do the test was very basic and worked well.
I had some 1/4'' od clear tubing and a 5/32'' (?) plastic vacuum T connector on hand, so I just melted one end of the T connector shut, plugged it into a ~7'' length of the tubing, put a few wraps of masking tape on the T connector tube, and wiggled the taped end into the drain hole. Didn't leak a drop (it only needs to work on the short-term, after all). The whole setup probably cost 2 bucks.
Thanks again, guys
-J. Conrad
