Author Topic: CB750K2 oil pump question.  (Read 1381 times)
« on: July 01, 2015, 10:24:44 AM »
Does anyone know...
Does the pop off valve in the oil pump effectively cap oil pressure at 60psi +/- ?
My relatively new engine is reading about 60+/-. Last year it read closer to 70. The only thing different is I put Elans kit in, which had a new pressure spring in it.
I did install an oil cooler as well. But it has a shut off valve right above the adapter which has been switched off, meaning no oil flow into the cooler. So, just a few inches of oil line has been added for this test.
Offline edwardmorris
  • Youngish
Re: CB750K2 oil pump question.
« Reply #1 on: July 01, 2015, 09:05:52 PM »
I've noticed that too, at idle under 1K it holds pretty steady at 60, revved up high enough it moves higher, but not too much. I can't find the post from Elan but he did mention that the bypass valve kicks in when it goes past roughly 62-65psi. And this is a good thing on these overbuilt pumps to avoid oil leaks. I'll post up the link if I find it again where he explained it better than I did ;D
Offline goldarrow
  • one day, i'll be an
« Reply #2 on: July 01, 2015, 10:05:44 PM »
Mine at idle is about 20, when running goes between 60-80, I don't spend too much time reading it, just quick seconds glance and keep my eyes on the road.
CB550 K0
« Reply #3 on: July 02, 2015, 03:47:43 AM »
20 here on fully warm engine with 20W50.  10 with fully warm engine with 15W40.
After extensive highway driving - like pushing the ton for several hours - she would show 10 with 20W50 and the oil light would come on in idle.
You can tell I find the oil gauge amusing feature  :)
« Reply #4 on: July 02, 2015, 06:16:45 AM »
Thanks Rafi et al. That's what I was thinking. Would like that post from Elan if you find it.
Like that gauge BTW,  ;).
