Thanks Wilbur, I'll look into a Fuel Petcock rebuild kit as well as the float seat and needle kit. Any recommendations where to purchase these parts?
Also, Float height adjustment. I have a clear tube w/fitting that I used on my 77' KZ1000 to check the float height. I'm seeing on the Forum that that measurement needs to be 3mm under the float base gasket?
If not using clear tube, what Float measuring gauge would you recommend and at what height on the gauge?
