Author Topic: What is this  (Read 2301 times)
Offline AlekStooge
  • can't afford cheap stuff
What is this
« on: July 02, 2015, 09:48:32 AM »
I took the top caps off my PD46C carbs to clean where the needle is and I found this spring next to my feet randomly. It is not from the arm that pulls the slides because I didn't touch that and it still in place. What could this be???
« Last Edit: July 02, 2015, 09:50:18 AM by AlekStooge »
Offline DaveBarbier
Re: What is this
« Reply #1 on: July 02, 2015, 10:21:29 AM »
Only thing I can think of in the PD46C carbs that would have that spring is one of the IMS's.
Offline RevDoc
Re: What is this
« Reply #2 on: July 02, 2015, 11:10:13 AM »
Looks like the ones on mine!
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
Offline Desert-SOHC
  • It's old
Re: What is this
« Reply #3 on: July 02, 2015, 01:24:32 PM »
There is a spring on the lever that holds the needle down inside the slide
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline DaveBarbier
Re: What is this
« Reply #4 on: July 02, 2015, 04:10:22 PM »
I don't remember any spring on the inside of the slide cylinder on the PD46C's. Pics or it didn't happen.
Offline RevDoc
Re: What is this
« Reply #5 on: July 02, 2015, 05:02:27 PM »
Dave, that one had me scratching my head too. Then I remembered there is a small, double hook-end spring on the linkage off the throttle bar. But, it is nothing like this coil spring shown, which is obviously a match for the one on the ASM screw.
Dana
'78 CB550K--Angie
Offline DaveBarbier
Re: What is this
« Reply #6 on: July 02, 2015, 06:49:19 PM »
Ohh, you're both totally right, my mistake. There is a spring there. You can see it in the #10 group.
http://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/E++1801.html#results
But yeah RevDoc, as you said not the spring in Alex's picture.
Offline Desert-SOHC
  • It's old
Re: What is this
« Reply #7 on: July 02, 2015, 10:47:24 PM »
3 springs on my arms
11 Ranger S/C 2wd
Offline AlekStooge
Re: What is this
« Reply #8 on: July 02, 2015, 11:02:16 PM »
Bingo, Dave you said it in the first response. I was thinking maybe it was somewhere on the needle but then I'm like naaa couldn't be. Never thought the IMS.
