Author Topic: The rickman returns, we'll sort of.  (Read 5425 times)
Offline captaink
« on: July 02, 2015, 01:09:11 PM »
Know I can post pictures, here's some of the progress.
Bearing in mind it's been less than a month
CR750 Replica Honda colours
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International  1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
Rickman 750 project
CR 750 dick Mann project
1964 series 1 E type jaguar
Gt40
" Greedy I Know "
Offline MoMo
  • Ride like you're invisible
Re: The rickman returns, we'll sort of.
« Reply #1 on: July 02, 2015, 01:12:46 PM »
Your photos did not post...Larry
Offline captaink
« Reply #2 on: July 02, 2015, 01:16:28 PM »
As I got the bike in black .
Stripped back to the bones
Starting all the pre fitting. When everything is cleaned, checked it will be stripped and sent for plating,paint etc
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline captaink
« Reply #3 on: July 02, 2015, 01:19:06 PM »
Well you got some pictures, even if you got one twice.
I'm doing this from an I pad, which isn't the best way.
Excuse any mispelt wooooooorrrrrddsss I pad tries to correct you
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline MoMo
« Reply #4 on: July 02, 2015, 01:24:08 PM »
Nickle plated weren't they?  Looks like you have as many tool boxes (4)as I do :P
Offline captaink
« Reply #5 on: July 02, 2015, 01:24:48 PM »
Wheels are back from the powder Coaters there stripped, tested, blasted, primed and coated.
Standard silver as they'll look good with the Orange
Hagen matched shocks.
I decided for safety reasons to get the calipers refurbed by the pro,s as all the seal and Pistons were replaced and pressure tested.
Better safe than sorry
Regards keith
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline captaink
« Reply #6 on: July 02, 2015, 01:28:47 PM »
The nickle plating was not to the quality I want and the swing arm was crap.
It will all be replated after many pre fits
And yes I have a few tool boxes, you can't have too many tools
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline captaink
« Reply #7 on: July 02, 2015, 01:34:32 PM »
This was a picture of the bike in 2009 I believe.
There is a member out there that knows or owned it.
Would be good to hear from him !
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline captaink
« Reply #8 on: August 20, 2015, 08:34:46 AM »
Update from the UK on the Rickman restoration
Engine stripped and vapour cleaned
Frame due back from nickel platers  next week with all the other bits either nickel or chrome polished and plated
Forks stantions being re chromed and then rebuilt with new internals
Seat has gone of to the upholsterers
Cylinder heads gone off to have new guides, valves etc.
Top casing will be sent off to have new APE studs fitted
Bearing in mind the difficulty in parts in the UK I'm considering a cycle x big bore kit
836cc new Pistons re bore etc.
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline captaink
« Reply #9 on: August 20, 2015, 08:39:35 AM »
Oil tank and some other bits powder coated
Battery tray was in a bad way with acid / rust damage but it came up superb
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline captaink
« Reply #10 on: August 20, 2015, 08:45:57 AM »
Started checking the gearbox components out.
I have ordered some new bearings that are easy to get and replace but everything looks in good order, all gears are really good order
Pics... The difference a cleaning makes !
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline captaink
« Reply #11 on: August 20, 2015, 08:49:17 AM »
Another picture
Pre fit then all gears will be washed
Final drive bearings have been ordered
« Last Edit: August 20, 2015, 08:51:48 AM by captaink »
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline slikwilli420
  • Master of Disaster
« Reply #12 on: August 20, 2015, 08:59:30 AM »
This looks great! Any special framed 750 is good in my book. I really like the Rickman and Seeley bodywork. Well done and keep up with the pics!
« Reply #13 on: August 20, 2015, 09:56:32 AM »
That vapour blasting is something else.  It makes the cast parts look new.
Offline MessnerMoto
« Reply #14 on: August 20, 2015, 10:56:36 AM »
Great build!
How much is a import tax in the UK for parts?
Offline captaink
« Reply #15 on: August 20, 2015, 12:04:34 PM »
Import tax into the UK from USA is shed loads and the couriers rip you off big time.
If there's nowhere else for the parts then it has to be I'm afraid
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline MessnerMoto
« Reply #16 on: August 20, 2015, 03:11:38 PM »
I have the same problem :(. I am waiting options what address to order to. France or Italy or Croatia. If you find someone selling those parts in EU PM me.
I found some wiseco piston kits in EU but they are not complete kits like cyclex's....
Offline jaguar
« Reply #17 on: August 21, 2015, 09:52:01 AM »
Neat project!
Offline captaink
« Reply #18 on: September 19, 2015, 01:05:53 AM »
Update on the nickel plating of the frame, it's back from the plating co.
They had a few issues with its size in the stripping tank but we got there in the end although it was a few week more
« Last Edit: September 19, 2015, 01:07:32 AM by captaink »
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline captaink
« Reply #19 on: September 19, 2015, 01:08:49 AM »
Can only send a few pictures at a time via the I pad
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline captaink
« Reply #20 on: September 19, 2015, 01:10:32 AM »
Forks stantions should be fully rebuilt soon but the trees are ready
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline captaink
« Reply #21 on: September 19, 2015, 01:13:39 AM »
Started the first pre build to ensure everything fits and that I have not lost anything.
All spacers and bushes have been remade in stainless and polished
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline captaink
« Reply #22 on: September 19, 2015, 01:20:31 AM »
Waiting for the larger F2 valves from the USA then the new guides, valves and springs etc can be fitted by the engine machine shop.
I'm going for a 836cc big bore kit which are easily available in the UK.
The leather seat will be made shortly and then all the panels will go off for paint.
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
« Reply #23 on: September 19, 2015, 01:41:32 AM »
That frame looks gorgeous... ;)
Offline Schenk
« Reply #24 on: September 19, 2015, 04:06:55 AM »
Wow! That frame is looking great
