Author Topic: F2 rods vs K rods. Polished, shot peened and balanced....  (Read 3665 times)
« on: October 23, 2006, 05:11:14 PM »
Sean Condon's rods. Notice the different big end cap on the F2 rod (on the right). Also notice the longer rod bolt on the right. You can see the differnce in the beams after the polish and shot peening(to put the surface in compression). Side pic of the big end shows where material came off to balance
Re: F2 rods vs K rods. Polished, shot peened and balanced....
« Reply #1 on: October 23, 2006, 05:12:24 PM »
...more
Offline scondon
  • Mmmm......tasty bugs
« Reply #2 on: October 23, 2006, 05:39:18 PM »
 Mike, thanks for posting those pics :) I'm sure they look even better in person ;D
    I made sure to note which rod went where on the crank when I took them off, but I didn't pay attention to which end faces forward( one side is stamped with a letter ). Will it make a difference which way I put these back on?
« Reply #3 on: October 23, 2006, 06:00:24 PM »
I install them with the bearing cut out(tang fits into) towards the rear. You had browns in them. I'd replace the nuts, modify a socket as not to chew up the new ones and plastigauge them. They will work well and will hold up to the 836 kit no problem. Big difference are the bolts which torque to 18.8lbs vs 14.5lbs for K's. You should gain a 1 to 2 tenths with the crank work(polished journals). This will be a nice combination Sean.
« Last Edit: October 23, 2006, 06:13:28 PM by MRieck »
Offline scondon
« Reply #4 on: October 23, 2006, 06:49:37 PM »
    Oooooh, those puppies look much better on my home PC(graphics card) :o  Thanks for the tips, Mike. I no longer "over obsess" about top end work, having done more than a few now, but since this is my first bottom end job I'm sure I'll pepper the forum with some silly Q's ;)
   Browns, huh? guess that answers my question as to whether the Green mark at the bottom of my case is a fluke. Is it OK to re-use the browns, or should I order up new ones?
Offline scondon
« Reply #5 on: October 23, 2006, 08:15:35 PM »
  Ok, best to read the manual before asking any questions. The Honda '78 750 F/K manual covers the crank and rods pretty well. Looks like I'll be measuring everything to find out which bearings to use. If those browns are still within spec should I replace them anyway?
  Mike, the manual covers both K and F models(1978) and only specifies 13-15.9ft-lb torque for the rod bolts. Where are you finding the 18.8ft-lb torque for the F2 rods? Also, the manual has this to say about bearing direction when installing rods:
CAUTION-
Be sure the bearing caps are installed in their
correct location and the bearing pawls point to
the front of the engine.
  This would be opposite to what you suggest, or am I misunderstanding it?
« Reply #6 on: October 24, 2006, 05:28:05 PM »
  OK, best to read the manual before asking any questions. The Honda '78 750 F/K manual covers the crank and rods pretty well. Looks like I'll be measuring everything to find out which bearings to use. If those browns are still within spec should I replace them anyway?
CAUTION-
OK. First, the torque figure comes from the Honda factory manual F3 supplement. I have the entire OEM Honda CB manual with every single supplement. Second.....which manual is that from(pawls in front) as the factory manual makes no mention or 2 editons of Clymers. I assume you have a Haynes? I've always installed towards the back though in checking  F3 rods taken off a crank they are indeed pointed forward. Hmmmm. I can only guess because the main pawls are torwards the rear BUT every picture I've every seen shows the rod bearing cut outs towards the rear. As for the bearings...they are toast (lots of crap embedded and.....just too tight) THOUGH I would get 1 set of brown and gauge them on the 4 journals. I like to run the the rods on the loose end. The last time I took my engine apart the rod bearings were perfect....no wear...nothing embedded. Greens might work better, run cooler and give a very small increase in HP (very small).
« Last Edit: October 24, 2006, 05:31:27 PM by MRieck »
Offline scondon
« Reply #7 on: October 24, 2006, 06:22:24 PM »
 :) Figured you had all the data sheets. The info I'm getting is from the Official Honda Shop Manual for 1978 750 K8 and F3. I got it in .pdf form from Terry long ago and it might even be available on this site. Since it covers both models I figured there would be some omissions considering the F3. When in doubt, ask someone who knows, thanks Mike :)
   I'll order up one set of Browns this week. Thanks for the tip.
« Reply #8 on: October 24, 2006, 06:28:32 PM »
I'm going to check my manual carefully Sean. I've just never seen that info in the American version. Mine comes in the official binder etc too!!
Offline scondon
« Reply #9 on: October 24, 2006, 06:36:40 PM »
   I'll send a CD of the manual  with your check ;)  I trust that your big, fat shop manual spanning all the years, and with the tech update sheets, has more info. But you can never have too many pictures ;D
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #10 on: October 24, 2006, 06:52:21 PM »
Oh man...
Mike,
You really know your stuff.
Sparty
1972 CB750 K2 Cafe' Style
« Reply #11 on: October 24, 2006, 06:54:08 PM »
Oh man...
Mike,
Sparty
Thanks...I try. ;)
eldar
« Reply #12 on: October 24, 2006, 07:46:15 PM »
You should let us know what you spent and where all you got the work done. SOmeday when I have extra cash, I want to do some of this. I would be nice to know what the cost would be and where it can be done.
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #13 on: October 24, 2006, 08:09:29 PM »
I swear one of these days - I'm going for the Carillos and regret not doing it 2 months ago.
100 horsepower and 11,000 rpm shifts -
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
« Reply #14 on: October 25, 2006, 04:29:42 AM »
Those things would easily handle 300HP. Just about everthing else would break but who's concerned with the little things. ;)
Offline scondon
« Reply #15 on: October 26, 2006, 07:56:19 PM »
Doh! There it is on the last page. I've got the "all inclusive" shop manual too but never looked at the very last page. Always looked at the '77 F2 supplement which does not have that torque spec( in my book ). Is it really only the '78 F3 rods that are "special"?
  BTW, I really just wanted to bring your pics back up top 'cause I didn't want to keep paging back for another look ::) ;D
Offline scondon
« Reply #16 on: October 30, 2006, 07:42:26 PM »
  The rods arrived today,Mike. As usuall the pics just do not do the parts justice. They look brand spankin' new...er, I mean "better than new,...better" ;D
   Ya know why I like sending you my parts for work? 'cause each time I open up the box I don't even recognize them as the parts I sent ya. All the care and work put in looks like what you would want if it was going into one of your own bikes. If there's a flaw in the part that a "noob" like myself would overlook, your quick to point it out. And I don't EVER get the feeling that you'd let something "iffy" get by just to get the work out.
    Yep, just got four balanced,polished,shotpeened rods and that all important "peace of mind", all for much less than the cost of two new rods from Honda ;) ;D ;D ;D
Offline jtb
  • An unlikely
« Reply #17 on: October 30, 2006, 07:54:29 PM »
 /quote]
Second That! :)
1977 CB750F
1985 V65 Sabre
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #18 on: October 30, 2006, 09:57:13 PM »
 8) I put some of them in my VW Golf (Rabbit to you yanks) engine many years ago when I rebuilt it. Horsepower-wise it didn't need them, but it needed new rods, and if you're getting anyway, get the best ;D
They didn't seemed to mind the odd missed gearshift and 10,000 rpm buzz here and there either, which was lucky ::)
1978 CB550 K3
1985 H100S
« Reply #19 on: October 30, 2006, 10:10:55 PM »
Fancy throwing money away like that, you could have bought some good players for your football team ;D ;D ;D ;D ;D ;D ;D ;D
Sam.  ;) ;) ;)
Offline CrisPDuk
« Reply #20 on: October 30, 2006, 11:13:23 PM »
Why would a team packed full of great players need any who are merely good ??? ;D
1978 CB550 K3
1985 H100S
« Reply #21 on: October 31, 2006, 05:56:27 AM »
Thanks Sean and John. I approach my work as though it was for my bike. It's been a pretty succesful, though sometimes frustrating, attitude. ;)
« Last Edit: October 31, 2006, 06:00:05 AM by MRieck »
« Reply #22 on: October 31, 2006, 11:49:51 AM »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Have you spotted the mysterious badger yet ?
Sam. ;D :D :) ;)
« Reply #23 on: June 16, 2009, 10:15:53 PM »
Oh man...
Mike,
Sparty
Thanks Art....again. ;)
« Reply #24 on: June 16, 2009, 10:19:11 PM »
CAUTION-
I still find this interesting as Carrillo's etc recommend the opposite....and I can see why. Comments?
