Author Topic: Will a 650 SOHC fit in a CB500 frame. .  (Read 2621 times)
Offline toolguy
« on: July 04, 2015, 09:11:58 AM »
Yes I did ao search for this but didn't find a definitive answer for putting it in a 72 CB500 frame. . .
If it fits the mounts are there any mods needed for the mount brackets?
And if someone has a picture of one in the 500 frame I'd love a link to it.
Thank you. .
Offline Tews19
  • I am no
Re: Will a 650 SOHC fit in a CB500 frame. .
« Reply #1 on: July 04, 2015, 09:31:05 AM »
Look up Scott S, a forum member here. He has done it. As Cal mentioned yes it will work. Best bang for your buck also. Much more powerful than the 500/550 engines. My next bike will be the 500/550 with 650 engine. Only downside is the exhaust selection. Very limited market
1970 Honda CB750 survivor.
Offline Scott S
« Reply #2 on: July 04, 2015, 09:32:36 AM »
 I'll post pictures later but, yes....it fits. I removed the sump....it's deeper than a 500/550  sump...and it was actually easier to get in the  frame than a stock motor.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline toolguy
« Reply #3 on: July 04, 2015, 11:40:49 AM »
Thanks for the answers. . .
 I picked up an almost complete 82 650 that "was" running fine in 2006. . .  and here's the bad part - before it hit a curb and took out the front forks. . The  rim survived but the owner removed most the front end except the bent forks and the wheel [which also survived amazingly], then lost the parts he removed, and left it sit outside for 9 years, which didn't help the remaining bike. . . .
I'm trying to decide if I should resurrect it. .  as it needs an entire front end and a gas tank. .  OR  pull the motor for another CB500 build. . .  I like the style and handling of the early 500 much better that the later 650's. .
Now if I can find a nice older 500 that's minus a motor, the question would be simplified. .
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: July 04, 2015, 01:00:11 PM »
If a hiyabusa motor can be made to fit the DS650 atv I have***.  Then all is possible!
***=the atv was made to fit the motor really....semantics
Offline Scott S
« Reply #5 on: July 04, 2015, 03:39:28 PM »
 Engine swap info starts on page 4:
http://forums.sohc4.net/index.php/topic,67907.0.html
'71 CB500 K0
'81 Yamaha XS650
Offline pangloss
  • CB500 K2 1975 NZ model
Offline roach374
« Reply #7 on: August 27, 2020, 09:17:41 PM »
Sorry for resurrecting a dead thread, but I'm considering doing this and want to know if the 650 engine will mean less room for the carbs (my aftermarket carbs barely fit int he cb500 frame as-is).
« Reply #8 on: August 28, 2020, 02:12:39 AM »
There are 2 different heads with different carbs on 650 so yours may not fit the head
Offline Scott S
« Reply #9 on: August 28, 2020, 03:11:05 AM »
 The 650 has the "manifolds" cast into the head. It only uses the rubber connectors to attach the carbs to the engine. The '79-80 engines used slide style carbs and the '81-82 used CV carbs. You can't swap carbs from early to late (and vice versa) without also swapping the head.
 I would measure the inlet spacing on the engine you're looking at and see how close it is to your carbs inlet spacing.
'71 CB500 K0
'81 Yamaha XS650
