Author Topic: Securing crank sludgetrap grubscrews  (Read 869 times)
Offline Greg H
  • When two cams is one too many .
  • Still crazy after all these years .
« on: July 04, 2015, 04:23:30 PM »
I've recently done the grubscrew mod to the sludgetraps on my crank . My question is , what should I do to secure them in place ? .
Offline Garage_guy_chris
Re: Securing crank sludgetrap grubscrews
« Reply #1 on: July 04, 2015, 05:08:57 PM »
I recently did the grubscrews too, with mine i tapped them so they would tighten up when the head got even with the crank. they got tightened to 70 inch/lbs. In addition I also used loctite high temperature red. I believe Loctite 272 i will double check when i get home.
I messed one up and didnt torque it before the loctite setup and had to remove it, well i had to heat the crank up with a map torch to 300 deg F + to even budge it and even then it took a huge amount of effort to twist out, and thats without being torqued to the 70 inch/lbs.
Offline Greg H
« Reply #2 on: July 05, 2015, 12:59:03 AM »
Thanks for your response to my query mate  ;).
I wasn't sure whether to use a centre punch  (like the stock balls) or to use loctite .
My screws tighten up to just below the level of the crank , so loctiting them would seem to me to be the better option . Cheers Greg "H".
« Reply #3 on: July 05, 2015, 08:40:52 AM »
Just had mine done along with a journal polishing. They got staked. Not sure if lock tighted though.
