Author Topic: rear wheel swap Q?  (Read 1520 times)
rear wheel swap Q?
« on: July 06, 2015, 08:54:29 AM »
 On a whim I bought a cb750 rear wheel assembly with an aluminum rim. I was thinking it was a goldwing rim on a k hub. Now I realize it's probably from an automatic bike. It has a 130 x 17 new back tire, if it's the auto hub is it a bolt on swap for a K bike?
Offline dave the welder
  • dave the welder
Re: rear wheel swap Q?
« Reply #1 on: July 06, 2015, 09:26:17 AM »
yes
don't buy it build it
Offline jonnycakes
« Reply #2 on: July 07, 2015, 06:49:28 PM »
It came with the wider spaced drive hub, but that can be switched out with the earlier K if you need that
'Matic-Fanatic
« Reply #3 on: July 15, 2015, 03:30:28 PM »
 Thanks, I was thinking that but wasn't sure.
