Author Topic: Washers for head nuts  (Read 715 times)
Offline zabzob
« on: July 06, 2015, 10:22:29 AM »
I'm about to put the head back on my bike and found that I have washers for 12 of the 16 nuts. Should I have washers for all of them? If I have to get replacements, are stainless or zinc coated recommended?
1975 CB750K5
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Washers for head nuts
« Reply #1 on: July 06, 2015, 10:44:25 AM »
Yes you need washers for all. Tip: Use a screwdriver to help guide the washers onto the studs in the spark plug recesses. Slide the washer down to the handle, and then put the tip of the screwdriver on the stud. Then let go of the washer.
Honda Part: 90485-035-000
Just order new ones.
--Evan
1975 CB750K "Rhonda"
Offline jonda500
« Reply #2 on: July 07, 2015, 02:56:31 AM »
make sure the other 4 aren't still stuck to the head?
A starter clutch thread:
Offline evanphi
  • Apparently I'm an
« Reply #3 on: July 07, 2015, 04:16:24 AM »
Good point jonda500!!! Check the spark plug recesses. They might still be there, especially if you had leaky pucks!
--Evan
Offline zabzob
« Reply #4 on: July 07, 2015, 11:21:29 PM »
Nope, no washers stuck to the head. I ended up picking up some new ones from a fastener store.
Thanks for the screwdriver washer tip evanphi!
1975 CB750K5
Offline evanphi
  • Apparently I'm an
« Reply #5 on: July 08, 2015, 06:36:24 AM »
No problem. I learned it from a forum member, and I figured I should pass it on. :)
--Evan
