I recently bought a 1976 CB750 for $250 and a stuck engine. The fins on the engine are mildly damaged. I have a 1978 CB750 K engine that has a crack upper crank case. I was thinking about taking the top end ( cylinder jugs, pistons, and cylinder head/cover) of the 1978 CB750 K and transplanting it onto the transmission of the 1976 CB750 engine. Does anyone know if this is possible? The 1978 CB750 K engine was running a month ago, but was spilling a lot of oil. I removed it and found a hair line fracture on the upper crankcase near the front sprocket probably from a chain that broke loose.
Thanks for any advice in advance
Arnold
