Author Topic: Newb Question #498 How to tighten the bolts on the oil pan. Honda Cb750 1978  (Read 639 times)
Offline briancwynn
  • If created then it is for a purpose!
Okay all, how do you tighten down these bolts.  I cant get anything to reach these bolts outside of my fingers?  Is there an order to this I need to follow?  Silly
Honda CB750 1978 K
Stock Carbs w/ Pods
125 main jets, stock slow, and 2 shims on the needle (equal to about raising it one clip)
M-unit
Bike broken down to bare bones and slowly put back together (except for the engine)
Offline briancwynn
Calj I had a bad feeling about using the word pan as well.  Dang it. I hate buying tools for 1 bolt. Here we go
Sent from my SM-N910V using Tapatalk
Honda CB750 1978 K
Stock Carbs w/ Pods
M-unit
Offline Garage_guy_chris
if you take out the three bolts holding the tank to the frame and shift the tank around you may have better luck, you could maybe use an adjustable wrench too but use the smallest one that will fit.
Offline Airborne 82nd
Better find another hobby. I had a shop fire spent $48K just for tools. Thank goodness for replacement cost insurance. Having the correct tool can be worth more than just the dollar value.
I have a few crescent wrenches that have worked going in from where the airbox sits. Aft line needs to be done up first.
