Hello All,
1977 CB550F, bone stock.
After my carburetor service last week, I finally got around to the vacuum synchronizing. Took the bike out for a warm up ride, parked it and started preparations for carb sycn. When everything was hooked up, the bike wouldn't start. Cylinders 1,4 were not firing. No spark. I thought I might have done something to the coils while removing the tank but finally I decided to check the timing and points. Static timing was fine but points where apparently dirty. Cleaned them out with a card and it fired up like nothing had ever happened.
So my question is, I cleaned, checked the point gaps and timing when I did the 3k a few months ago. I have ridden the bike about 600 miles since that time. How often do you check your points?
Another question I have is, should I think of upgrading to an electronic ignition?
Thanks for your guidance.
