Author Topic: CB550 - The 1976 brat project (wiring with a M unit)  (Read 11897 times)
Offline 540nova
Re: CB550 - The 1976 brat project (wiring with a M unit)
« Reply #25 on: October 20, 2016, 02:12:29 PM »
Your solenoid is wired wrong. You can't have the battery and starter motor on the same pole. The left pole, currently going to ground, should have a connection to the starter motor. Omit the ground connection.
Offline hashvm
  • It's not a lesson without you making mistakes!
« Reply #26 on: October 20, 2016, 02:33:34 PM »
Are you planning on running the M-Button?
The open line at th "points/ignition" box, why do you have that? Are you running points or electronic ignition?
You should be running power to the ignition directly from the AUX port. Power to the coils you can run through the KILL switch, but those Emgo switches will probably not enjoy the amperageor long.
The RED lead you have looped from the LOCK port to M-Unit power is wrong. Battery to M-Unit. Key BLACK wire to LOCK.
Have a glimpse at this PDF to tide you over until I finish yours tonight.
http://forums.sohc4.net/index.php/topic,159934.msg1844547.html#msg1844547
Hey Cal,
- yes I'm running the M button
- I'll be running electronic ignition (Dyna DS1-2)
- So if I don't the kill switch through the coils 12V should I connect it in series after the ignition switch?
- I have the two colors before the lock to represent the key switch (I thought that's where you connect the key)
Thanks for the PDF and thanks for the help!
Offline hashvm
« Reply #27 on: October 20, 2016, 02:34:18 PM »
Got it, I'll change that
thanks for the help
