Author Topic: 1970 cb750KO gauge restoration  (Read 1637 times)
Offline kbart1
« on: July 13, 2015, 03:42:42 PM »
hey guys
i would like to restore my 2 gauges for my 70 KO. i have searched and couldn't find any info on disassembling these particular gauges. the problem is that the black body of the gauge has a lip that wraps around the back side of the metal portion of the gauge so it looks and has proven impossible to get the two parts apart without either breaking the lip or the entire body. i would like to buy one of the kits which has the body / lens / jewels etc. but cant figure out how to re and re these parts without damaging them, or breaking the new parts putting it back together. anybody have any ideas or tricks?
thx a lot!
kent
Offline Desert-SOHC
  • It's old
Re: 1970 cb750KO gauge restoration
« Reply #1 on: July 13, 2015, 07:10:42 PM »
There is a crimp ring that hold the 2 pieces together, you can get new ones to replace them.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Charlie David
« Reply #2 on: July 13, 2015, 07:19:25 PM »
70 K0's had plastic housings sealed to the metal frame with what appears to be silicone or glue. I've never seen a crimp ring that I can remember...but I'm old.
I just wanna ride my motor-cy
1970 K0 CB750
Restored
Thank you Bill Benton
1970 K0 CB750 Rat Rod
1970 K0 CB750 Current Project
1970 K0 CB750 Frame & Engine
1971 K1 CB750 Frame & Engine & Parts
1974 K4 CB750 Cafe Frame & Parts
Offline Rmart
« Reply #3 on: July 13, 2015, 08:20:33 PM »
There should be a silver crimp ring holding the 2 halves of the body together in the middle.
Go down to your local paint or hardware store and ask for a paint can opener (they are free most of the time) it's metal and has a bottle opener on one end (you will need it before your done
Offline kbart1
« Reply #4 on: July 13, 2015, 10:24:55 PM »
no crimp ring OR adhesive. it has a plastic lip that is part of the plastic housing that wraps around the backside of the gauge. making practically impossible to take it apart without breaking the housing.
thx
kent
« Reply #5 on: July 13, 2015, 10:31:15 PM »
You have to our cut it with a knife ....someone will come along that knows the procedure .
Offline kbart1
« Reply #6 on: July 14, 2015, 06:49:36 AM »
thanks but i am not sure about what you mean? "You have to our cut it with a knife". perhaps a typo? i think as they are rough anyways i will break them off to free up internals and then hope that someone comes along that knows the procedure.
thx!
kent
« Reply #7 on: July 14, 2015, 09:00:59 AM »
Go to lecrams Site..he advertise on here 750 guages..
 Look at some Ko or sandcastle restore threads on here you will find it.. Yes they get cut off
Offline Johnie
« Reply #8 on: July 14, 2015, 01:52:18 PM »
I have done a few and you just break off that plastic ring edge all around the bottom of the underside of the gauge. The gauge will then slide out. Then replace the entire plastic housing with one from LeCram and you will glue that one in place.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline kbart1
« Reply #9 on: July 14, 2015, 09:14:50 PM »
thanks for all the help guys. i just bit the bullet and started to take these apart and it all went fine. now i can order the parts from leCram when he's back from holidays and rebuild. i ran them up with a drill motor and they seem to function fine. i have a couple loose jewels but i can get those parts as well obviously. the only sticking part is the trip reset function, that seems to be fairly tight but it does turn and reset. i think it just needs to be cleaned up and some lubricant put on it. that being said is it possible or advisable to lube the gauge mechanism's? if so with what? thanks for you help. you just saved me hundreds of dollars, love this site!
thx
kent
