Author Topic: I should stop hauling CB750's home!  (Read 5346 times)
Offline KayOne
« on: July 18, 2015, 09:29:17 AM »
Familiar story on SOHC.net, Hauled home a K1 yesterday. Wasn't looking for a bike but a long time football and lacrosse coaching buddy called me and told me to haul this away. I have been hounding him for 10 years, offering to help him get it back on the road but he always refused the offer...now I know why, check out the frame kit!
It has a few period correct bolt on parts from the day. The paint on the tins is incredible. I cleaned them up and they looked like new. The metal flake paint is so thick that I swear the tank weighs 20lbs.
Can any one identify the header? I think it may be an RC.
I don't think this bike is worth restoring as the frame is cut and the front forks are so far gone  :(
Here are a few pics:
CB750 K1 restored
1979 CB750Fz - original except for exhaust, 14000km
1984 VF45F Interceptor - all original, 12000 km
1968 S90 - all original, 2100 miles
1973 H2a, Restored
1973 H1D, next project
CB750K1 (sold)
1976 KZ900 (sold)
1981 CB900F (under restoration)
2015 Yamaha FJ09, my appliance rider
Offline dusterdude
Re: I should stop hauling CB750's home!
« Reply #1 on: July 18, 2015, 10:20:11 AM »
Love the paint,please dont change it
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline dusterdude
« Reply #2 on: July 18, 2015, 10:20:35 AM »
Btw,k1's rule
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline BPellerine
« Reply #3 on: July 18, 2015, 11:19:55 AM »
the head pipe looks rc not sure about the can though.bill
1978 CB 750K ard and webers
another anfob
« Reply #4 on: July 18, 2015, 11:33:07 AM »
I'd put a frame kit on there and put some slightly shorter fork tubes and ride it Dennis Hopper style!
Offline KayOne
« Reply #5 on: July 18, 2015, 01:09:46 PM »
Not a chance! Never considered a frame kit, great idea, the rest of the frame is in better shape than the K1 I restored. Only problem doing this one is I am finishing up a 83 V45 Interceptor and have  matching '73 H1 and '73  H2's next in line for restoration.
Looking for more RC goodies, I pulled the valve cover, just a stock cam but the engine turns over and is clean inside. It has 24 000 miles on the clock. The engine has been apart though so there is still hope I could find a big bore kit :)
CB750 K1 restored
1973 H2a, Restored
CB750K1 (sold)
1976 KZ900 (sold)
« Reply #6 on: July 18, 2015, 01:42:47 PM »
We can help you find nice RC parts, here ya go....
http://www.ebay.com/itm/CB750-Honda-RC-Engineering-Cylinder-73mm-Piston-Drag-Race-Cafe-Chopper-CB-750-bb-/301689131830?hash=item463e12d336
BTW - I am just about finished with my H1 restore...
...and have just started on the H2!
« Reply #7 on: July 18, 2015, 03:23:09 PM »
Period correct resto is imho the only option.
I have a pair of long tubes you can have cheap - they are like 3-4" over and in goodl shape.
Offline enwri
  • So that noise is normal?
« Reply #8 on: July 18, 2015, 03:59:01 PM »
Needs more chains.
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
« Reply #9 on: July 18, 2015, 04:01:23 PM »
Shorter or stock tubes, and a handlebar change, it will look pretty good.... I like it..pipe does look like an RC except. The can as Bill said.... Can you show a front shot of the pipe.
« Reply #10 on: July 18, 2015, 05:38:20 PM »
Frank - is there enough frame there to attach your frame kit? Looks to only be 15mm or so.
Online madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #11 on: July 18, 2015, 05:47:54 PM »
I love it! If the frame tubes are cut too short, someone should be able to provide some tubing from a hacked frame. At least enough to accommodate the bolt in frame kit. Maybe someone that recently installed a frame kit? Got the "cut offs" still laying around?
The forks definitely seem too long. I would probably go with shorter fork tubes, but still maybe 2" to 4" over stock.
Let me know if you want to ditch that twisted highway bar!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #12 on: July 19, 2015, 12:09:23 AM »
Back is too short. But a machined plug is easy to make. Slip fit inside the frame tube..about 3/4-1inch long then 1.006 for 1.625 or longer......... Tap them in plug weld and weld around.. That fixes that end.. Looks like you will have to build the middle section if you cant find one... . Its doable..
Offline KayOne
« Reply #13 on: July 19, 2015, 09:16:13 AM »
That is what I want my H1 to look like Stev-o! Canadian $ is so bad the triples are on hold, that's why I found the Interceptor to do while I wait.
I have a 78 750K rolling chassis. The tubes appear to be the same. maybe get 754 to machine some plugs and use donor tubing? The bike is beginning to grow on me and it might be a cool Saturday night cruiser :)
Will the 78 fork tubes work? The measure out 35mm. The forks are so damaged it looks like the K1 fork tubes must be heavily damaged by thrust wear. If this is the case I will have to swap over the 78 lowers also.
Swap over a front end, buy some cool bars and install front signal lights...
any one have a decent K1 tach, this one looks like this one has hit the pavement too many times!
Thanks for the help guys, ideas are always welcome :)
BTW the RC Ebay dude lives in my home town.
« Last Edit: July 19, 2015, 09:22:16 AM by KayOne »
CB750 K1 restored
1973 H2a, Restored
CB750K1 (sold)
1976 KZ900 (sold)
« Reply #14 on: July 19, 2015, 10:07:57 AM »
78 fork will fit but you can't use your old caliber and hanger..
If you want to cut the piece out of the 78......cut oversize then trim to fit.. Then weld the whole thing in completely. You may have to split the triangle, to get lower tubes to line up. Get the whole thing reinstalled before cutting for a frame kit.
Offline KayOne
« Reply #15 on: July 19, 2015, 04:45:04 PM »
Will welding in the patches without plugs be strong enough?
Here is a shot of the muffler from the rear, RC?
CB750 K1 restored
1973 H2a, Restored
CB750K1 (sold)
1976 KZ900 (sold)
« Reply #16 on: July 19, 2015, 05:51:17 PM »
Iwould calm it replacement. Tubing..not patches. If you are going to weld new lower raise in (to cut later). The only way you will get an internal. Sleeves to notch the tubing,  then slide the sleeve back before welding.   But it won't be a real tight fit... The front joint if using my kit can be simply clamped... To weld the back    . You can also use video block or a similar fixture.
Offline BPellerine
« Reply #17 on: July 19, 2015, 06:26:32 PM »
don't think the muffler is rc not the same,rc one is diff shape and removable.bill
another anfob
« Reply #18 on: July 19, 2015, 06:51:01 PM »
 I've repaired worse, and I agree with Frank, I think he meant V block but a piece of angle will line it up too. I cut a notch in my frame repair, slid the inside tube into the joint and tig welded it all up.
« Reply #19 on: July 19, 2015, 06:53:11 PM »
that paint is just spectacular!
« Reply #20 on: July 19, 2015, 07:30:13 PM »
How can you not haul that home? too cool.
