So current state of build is this.
Frame modifications are done more or less. I am waiting for tarozzi rear sets to arrive so I can test rear brake cylinder. Front brake cylinder is mounted below tank. I need to make custom brake cable.
But I will need to make something like 754s frame kit. I thinks 754s kit perfect. Just shipping would cost me more then kit....
Metal shaping work has begun... I hope I will get the tank and the tail before the end on this month. I will post pictures of progress.
I ordered some things from CycleX for my engine... It will be a 836cc
Currently I am designing all the chain tensioners. I need to correct weak points of cb engine before I upgrade the power
![Smiley :)](http://forums.sohc4.net/Smileys/default/smiley.gif)
you can follow the design process in high performance part of forum.
Also I will vapor blast all the engine parts(cases, head etc...) and I will do vapor blasting by myself with some improvised equipment because where I leave no body is doing good vapor blasting
