There is much small stuff going on. I haven't updated the thread for some time... been busy. I received so much stuff for the engine for engine. But first some small custom stuff
I finished final design of cam and primary chain tensioners.
I cut on laser some stainless steel sheets.
I am waiting for plastic to be cut on cnc.
Also I made some central wheel for cam tensioner( explanation High Performance ยป CycleX HiPo cam chain tensioner & primary chain tensioner). It is made of 4721 steel and then nitrated to 55Rc.
And I made several torsional springs for primary tensioner. I wanted to test different diameters of wire. I ended with 3mm black wire for springs. So it is a HD spring 0.1mm more in diameter then stock
... And of cores you have to heat threat your springs if you want them to last...
And some custom rocker shafts. 4721 steel nitrated to 55RC
And this is still cheaper then oem things
One of the reason why I am doing this
