Author Topic: MessnerMoto - CB750 f2 - Some Parts are now available from build!!  (Read 86126 times)
Offline MessnerMoto
Re: MessnerMoto - CB750 f2 - Parts are now available - CNC oil pump rotors
« Reply #325 on: September 22, 2018, 07:42:11 AM »
Also I have made this. Five(5) sets are available.
They are made for gsxr 600/750 k6/k7 front end conversion.... also only for cb750
PM if you are interested
They look nice :)
« Last Edit: September 22, 2018, 09:58:29 AM by MessnerMoto »
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #326 on: September 22, 2018, 09:31:49 AM »
Mirko are those for 42mm tubes? Do the have fork stops?
Duh, that’s a top tree bridge, gotcha
« Last Edit: September 22, 2018, 09:33:54 AM by Medyo Bastos »
Offline MessnerMoto
Re: MessnerMoto - CB750 f2 - Some Parts are now available from build!!
« Reply #327 on: September 22, 2018, 09:52:19 AM »
This is for 50mm forks.... And only for gsxr forks conversion. gsxr k6 k7 600 an 750.... you need bottom tree of gsxr for this to work
« Reply #328 on: September 23, 2018, 08:07:10 PM »
Mirko,
These look nice. Have you considered making the whole trees with more offset than the GSXR?
Offline MessnerMoto
« Reply #329 on: September 24, 2018, 05:03:19 AM »
Mirko,
that would be to expensive for general public because it would demand lower triple tree also.
This is affordable solution ;)
Offline MessnerMoto
« Reply #330 on: September 29, 2018, 01:00:07 PM »
Not a valid vimeo URL
Here is the latest hires video from this build
Enjoy ;)
Offline kmb69
« Reply #331 on: September 29, 2018, 01:17:17 PM »
Enjoy ;)
Mirko, Looks awesome but it would be nice to hear the bike instead of that background music.
Offline MessnerMoto
« Reply #332 on: September 29, 2018, 01:36:43 PM »
Enjoy ;)
that was the plan... but we had some problems with recording equipment... we recorded really high quality sound of the wind:)
next video ;)
Offline MessnerMoto
« Reply #333 on: November 04, 2018, 01:59:46 PM »
    ...And if anybody wants miniature control buttons, send PM;)
    • CNCed from Al 6082 T6.
    • They can be preordered in pairs or only just for left or right handlebar.
    • Available in brushed or polished finish.
    • IP67 momentary switches.
    • 45mm diameter.
    • For 22mm handlebars.
    • Black Wires are provided and welded to buttons.
« Last Edit: November 05, 2018, 10:03:09 AM by MessnerMoto »
« Reply #334 on: November 04, 2018, 08:17:31 PM »
Man are those ever nice, can you give out the price?
Incredibly beautiful piece of alloy.,
 Are they momentary switches, or can they stay on ?
« Reply #335 on: November 05, 2018, 08:36:00 AM »
Ditto!
Offline MessnerMoto
« Reply #336 on: November 05, 2018, 09:59:19 AM »
thanks ;)
Those are momentary switches. Sent you PM ;)
Offline MessnerMoto
« Reply #337 on: November 19, 2018, 01:43:24 PM »
... Actually I never stoped upgrading my bike.... After several thousands of km I had to change some week spots.
Original 3D printed in ABS plastic holders, reinforced with stainless steel plates, for headlight didn't hold well. You can see them in first photo. They are holding to much weight... Headlight assembly weights above what I anticipated... Originally I wanted to 3D print holders in Aluminum but it it is still to expensive.
So next best thing CNC ;)
Offline Godffery
  • Godffery's Garage
« Reply #338 on: November 20, 2018, 03:18:57 AM »
 Beauty...!!!
Offline MessnerMoto
« Reply #339 on: November 20, 2018, 04:29:27 AM »
thx;)
I will assemble everything it in next several days stay tuned ;)
Offline MessnerMoto
« Reply #340 on: November 23, 2018, 12:57:10 PM »
Friday night ;)
Offline Godffery
  • Godffery's Garage
« Reply #341 on: November 23, 2018, 04:48:20 PM »
 Got'a Love it when a plan comes together so nicely!
« Reply #342 on: January 21, 2019, 06:56:37 PM »
Bit late to the party but beautiful build! You are truly an artist! Could you tell me what oil cooler you used for your build?
Thank you!
cheers
Andy
Offline MessnerMoto
« Reply #344 on: February 07, 2019, 06:06:59 AM »
Just to show sneak peek to people from forum of the final production version of switches. They will be ready for shipping next week.
If somebody needs them for project PM fast before it runs out ;)
« Last Edit: April 28, 2022, 06:12:45 AM by MessnerMoto »
« Reply #345 on: February 07, 2019, 11:24:19 AM »
Very nice, Mirko!
Offline MessnerMoto
« Reply #346 on: February 08, 2019, 10:09:39 AM »
Thanks ;)
switches pic
« Last Edit: April 28, 2022, 06:14:48 AM by MessnerMoto »
Offline Godffery
  • Godffery's Garage
« Reply #347 on: February 08, 2019, 06:27:29 PM »
Are the wires routed internally?
If so; How is that done with this one peace housing design?
Offline MessnerMoto
« Reply #348 on: February 09, 2019, 11:24:00 AM »
The cable exits the button on the side, bellow handlebars. So it is not visible
I saw how other companies are using thin wires and root them in handlebars. Thats completely unpractical and wires break..I am using 0.22m2 wires in cable. They are physically strong... similar products use 0.14m2
I even added 3D printed plastic support for cable so it will not break
« Last Edit: February 09, 2019, 11:28:12 AM by MessnerMoto »
Offline MessnerMoto
« Reply #349 on: February 09, 2019, 04:24:53 PM »
The cable support is a nice idea, but there are many who wish to route the wires internally to the bars, especially clip-ons.
One reason “others” use a thinner gauge wire is the terminal screw post beneath the button is very, very small. A thicker wire doesn’t really fit. Add to that, the wires leaving the terminal need to avoid racing against the metal bars, causing a short. It’s all very tight tolerances.
yep and there is a lot of people complaining that those thin wires are failing.... And then it is big pain to fix them because they are routed inside. Completely impractical if you want to drive a motorcycle. Wire needs to be mechanically strong to resist fatigue failure.
but the main reason why they are left to be routed inside the switches/clipons, my opinion, is because it is much cheaper for machining of switches and is much cheaper to leave to end user to think how he is going to solve cable exit/routing...
This is more expensive(to produce) solution but much more reliable, practical and visually you don't see the cable because it follows the clip ons from below. My buttons are soldered and isolated. You can see it on my bike how it looks.... You don't see the cable.
but this can be only just mine opinion ;)
« Last Edit: February 09, 2019, 05:41:12 PM by MessnerMoto »
