Author Topic: bad starter solenoid ? no clicking no start  (Read 8318 times)
Offline 78whiteorbs
Re: bad starter solenoid ? no clicking no start
« Reply #25 on: July 23, 2015, 12:46:00 PM »
The voltage is flowing from one wire passing through the switch and the starter button completes the path back to the solenoid. Is this right? I have no voltage coming out of either yellow / red or green/red
Nor would you, as both of these wires are ground circuits. The solenoid should have a black wired to it to deliver power, the Y/R completes ground when the START button is pressed. G/R is NEUTRAL switch.
Pull in the clutch lever then try again...
Tried that Didn't work. All the solenoid for sale for a 76k cb750 only had two wires not three unless I am missing something here.
Mines like this....http://m.ebay.com/itm/1976-HONDA-CB750K-CB750-FOUR-STARTER-SOLENOID-/191295904947?nav=SEARCH
Is this not the correct one?
Offline 78whiteorbs
« Reply #26 on: July 23, 2015, 01:48:06 PM »
Red
Offline 78whiteorbs
« Reply #27 on: July 23, 2015, 02:56:24 PM »
Roger
