Author Topic: 1974 CB550 wiring diagram (simplified)  (Read 9009 times)
Offline iambleach
« on: July 22, 2015, 12:58:40 PM »
Hello all! First time posting. I have been building a 1974 CB550 cafe racer for the last year and a half. I have not been able to find a nice cleaned up simple wiring diagram so I made my own. So, here it is. I have a Dyna electronic ignition instead of OEM points, and a regulator/rectifier combo. Other than those, everything else is original.
So heres my diagram. I hope someone else finds it helpful.
Offline iambleach
Re: 1974 CB550 wiring diagram (simplified)
« Reply #1 on: July 22, 2015, 02:31:34 PM »
Calj737, I had the fuse between rectifier and battery but a buddy said to move it between battery and ignition. You think I need both or just switch where it is currently?
As far as the SSM unit. I still have no idea what that even is. I was following another simplified diagram for that.
So if I got rid of the starter, I don't need the SSM either?
Thank you for your help, and once I get a reply from ya, I'll post an updated diagram.
Offline iambleach
« Reply #2 on: July 22, 2015, 03:45:32 PM »
Thanks again. I figured you were saying to use two, I just wanted to clarify as I'm in my garage right now.
As far as that brown wire going to a black:
I had a custom tank/seat made with a tail light. The tail has a red ground, a red power to main light, and a black for the brake.
So the original g/y from the rear switch is now a tan wire.
Totally didn't think about how those were different than normal when posting my diagram. But thank you for the info.
Oh, and I forgot all about the mounting bolts and seal on the starter! Wish I read your reply before I found that out on my own!
Offline nicks2319
  • Youngstown, OH
« Reply #3 on: July 22, 2015, 09:17:13 PM »
For those searching I usually see people post this
Offline iambleach
« Reply #4 on: July 24, 2015, 07:35:18 PM »
Ok, lets try this again. Updated simple wiring diagram for a 1974 CB550.  No starter, and a Dyna electronic ignition.
Offline 1974CB550
« Reply #5 on: February 03, 2017, 09:15:47 PM »
WOULD ANYONE BE INTERESTED IN A BREND NEW WIRE HARDNESS FROM NICE 16AWG HIGH TEMPERATURE WIRE????
I'M REDOING MY HARDNESS COMPLETELY FROM SCRATCH AND HAVE EXTRA WIRE AND NOW KNOW THAT WHOLE SYSTEM VERY VERY GOOD AND SEE IF ANYONE WOULD BE INTERESTED OF BUYING ONE FR9M ME??
