Author Topic: ARD Magneto  (Read 120688 times)
Offline dusterdude
Re: ARD Magneto
« Reply #225 on: May 11, 2007, 12:16:59 PM »
damn,thats slicker than snot
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline puppytrax
Re: ARD Magneto
« Reply #226 on: May 13, 2007, 11:55:13 AM »
...and speaking of snot...here's a guy selling an ARD Triumph conversion...with no cover, points, mounting plate, condenser, or coil in the FM magneto...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290114810534
Two viewers emailed him about that...here's his reply...
All that I have is what is in the pics. Some miscelaneous nuts and bolts. The guts for the mag is the easiest of the stuff to find. It is like any other mag on the market. Any tractor supply store that rebuilds magneto's will have the parts and some aftermarket mag companies would have them as well.
Someone's willing to pay $306+ for it...   :o ::) ;D
With a day still to go...
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline Jim F
  • go baby go
Re: ARD Magneto
« Reply #227 on: May 14, 2007, 09:41:43 PM »
I think who ever gets that is gong to have to set down and have someone kick him hard for being a @#$% @##
lol
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline puppytrax
Re: ARD Magneto
« Reply #228 on: May 15, 2007, 03:35:13 AM »
It went for $435...   :o ::) :P
Offline Jim F
  • go baby go
Re: ARD Magneto
« Reply #229 on: May 16, 2007, 08:40:41 PM »
Rich
Send pictures of the belt box's when done. Would love to see your work.
Ive been so busy in the other side of the shop (looking threw the microscopes welding)
that I haven't done anything but paint the pulleys and try an figure out where to mount
the degree wheel to time it
I guess it well get done around January of next year
too many projects
Jim
Offline cafe75-550
Re: ARD Magneto - Mag help needed!!
« Reply #230 on: July 08, 2007, 05:05:47 PM »
Ok guys, so its been forever since I bought this ARD MK2 mag, and after some modifications and parts tracking I finally have it mounted on my 550. I have it temporarily hooked up, and using my electric starter to turn the engine I've been doing some troubleshooting. Does anyone know any of the specs for the ARD CDI mags? Like what kind of voltage I should be seeing at mag, or coming out the "silver box" (going to the coil)? I would assume that I would have either 12 or 6 volts going to the coil (I don't have any now).
At the moment, checking voltage at the blue wires coming off of the black box on the stators, I'm getting 1.7 Volts AC from one, and .35 V AC from the other. This doesn't seem like much, but I guess its a pretty low RPM as well. So I guess I want to know a few things, if anyone knows (Jim? Terry? Anyone?) ???
1. What kind of voltage should the mag be putting out (AC) at cranking speeds?
2. What is the silver box?
3. What kind of voltage should I see coming out of the box going to the coil?
4. Has anyone had any contact with Alan at ARD since they lost the lease on their shop, or has a way of contacting him? (in case I need work done on this thing)
Ps. yellow wire is for a kill switch, I've tried it in both configurations with the same result, no voltage to the coil. ::)
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
Offline cafe75-550
Re: ARD Magneto
« Reply #231 on: July 08, 2007, 09:21:35 PM »
I have a ARD CDI for a Kawasaki and I get about 10/11 volts from the 2 wires going to the silver box when spinning it by hand. I dont have the silver box or coil, but you do need specific ones to work with this set up and not just any coil will work with it.
 Daniel
Well that doesn't sound good! :-\ I assume you mean on the mag side of the box right? I figured that all of that stuff was specialty, although the coil I should be able to figure out, either ballast or non-ballast and 6 or 12 volts (more likely 12), but that doesn't sound like its my biggest problem at the moment, since I'm not seeing anything close to those kind of volts anywhere. Any thoughts on the low voltage?
Bryan
New bike!
Offline cafe75-550
Re: ARD Magneto
« Reply #232 on: July 08, 2007, 10:21:10 PM »
I think I found one of my problems. I tried to reset the gap between the rotor and the stators down a little closer to the .006" minimum spec'ed on the instructions and found a wobble in the rotor, which is no doubt from spacer I had to make to get the rotor lined up depthwise in the stators (another 750 to 550 issue). Even in the partial revolution there was a voltage difference, so I guess its back to the shop to machine a new spacer. Also need to re-solder the wires onto the "black box", looks like they're getting pretty loose. Sigh  :-[.
Still looking for any info I can get!  ;D
New bike!
Offline Jim F
  • go baby go
Re: ARD Magneto
« Reply #233 on: July 09, 2007, 05:15:05 PM »
Do you need to run a coil with the MK2 versions?
I didn't think you needed coils with the ARDs
at least with mine you don't but I have the MK1 version
interesting
keep me posted
Jim
Offline Jim F
  • go baby go
Re: ARD Magneto
« Reply #234 on: July 10, 2007, 04:38:24 AM »
Terry, Rich
where are you guys?
how are the projects going?
mine is still in limbo, but I did get my
pulleys painted and mounted.
took an air tool to turn in the bolt to the magneto
shaft and when it locked down and started to turn
the mag, ( i have the cap and rotor off) there was
an ark the went from the copper plate the the button rides on
to the screw that holds down the condenser, about .500 of an inch away
very pretty blue arc of high voltage go fast electricity (Georgia talk there)
I might get it cranked in a year or so
lol
Jim
Offline Schultz
  • Danny Boy this is a showdown!
Re: ARD Magneto
« Reply #235 on: July 10, 2007, 06:03:49 AM »
I've been lurking here from time to time and I thought it was time to introduce myself. I started reading this thread yesterday and just finished catching up. Very interesting. I have two ARD F/M mags for CB750s and have used them from time to time. I like them, but I also like to ditch the starter, cut down the alternator rotor and install a small gel cell battery.
I was wondering if any of you guys have seen the ARD/Hilborn mechanical fuel injections for CB750s? It runs a belt off the crank just like the F/M adaptor except there's also a fuel pump driven off the belt for the injection. Common on CB750 engined sprint cars. I've got one I was going to put on a 1000cc dragbike project. I still need to find some parts like an RC Block. Here's a link to some pics of Russ' original bike:
http://www.randymott.com/collins.htm
I'm a USMC jet mechanic currently stationed in Iraq. I'll be home in two months and will be able to send/post some pics if you're interested. Keep up the good work.
« Last Edit: July 10, 2007, 11:58:18 AM by Schultz »
Offline dusterdude
Re: ARD Magneto
« Reply #236 on: July 10, 2007, 06:27:52 AM »
welcome and ooooh rahhhh
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Jim F
  • go baby go
Re: ARD Magneto
« Reply #237 on: July 10, 2007, 07:40:36 PM »
ooooo rahhhhhh   is right and keep up the good work over there
That is a trick looking bike.
Big-Jim
Offline puppytrax
Re: ARD Magneto
« Reply #238 on: July 11, 2007, 01:50:26 PM »
Hey Terry -
One of your neighbors is selling his F/M ARD mag setup...   ;D
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=ADME%3AB%3ASS%3AUS%3A1&viewitem=&item=140137363437
I could swear I've seen this on eBay before...   :P
Offline Jim F
  • go baby go
Re: ARD Magneto
« Reply #239 on: July 11, 2007, 05:49:25 PM »
Hey Rich
how are ya
haven't herd from you in a while
how ar the belt box's going?
I haven't herd from Terry in a while but I am sure
He is lurking around somewhere
I am watching that ARD too
lol
Jim
Offline puppytrax
Re: ARD Magneto
« Reply #240 on: July 11, 2007, 06:16:47 PM »
big-jim -
I'm working on getting my CL450 straightened out (the avatar)- it's on the road and runs OK, but the carbs are gummed up, so I'm putting a new cleaned-up set on...and my Vette transmission is locked in reverse, so that needs to be trouble-shot real quick, so I can get it off the road before the inspection runs out (then they will give me a 10-day extension when it goes back on, otherwise I'll have to have it flat-bedded to the inspection station)...plus I've been under the weather...and real life is not all that good (my Weimaraner is losing weight fast; way too fast)...  :(
Otherwise, the belt boxes & magnetos are coming along...but slowly...I'm in no real hurry...
I gotta start cutting back...too much work planned, not enough getting done...and no time for doing anything...   >:(
Re: ARD Magneto
« Reply #241 on: July 14, 2007, 06:54:37 PM »
Hey Rich
how are ya
lol
Jim
G'Day Guys, yeah, I've seen that ARD on EBay a few times, he first put it on after I sold mine to Big Jim. Sorry I took so long to get back to you, I've been working at an Air Force base for the last two weeks and will be for another two more, with virtually no internet access due to the security restrictions there, but I'm home for the weekend, and am doing some work on a special front end set up for a CB750 using:
Honda CB250RR triples (10mm wider and take 37mm fork legs)
Suzuki GS1000 forks
Suzuki GS750 hub
Suzuki GSXR1000 4 pot calipers
Obviously there's been heaps of mods to make it all work, but it's looking good so far. I've had to space the GS1000S discs out 10mm either side of the hub so the big calipers will (just) clear the spokes, space the speedo drive out 10mm as well so I can still use the mechanical speedo, make up mounting brackets from 10mm plate for the calipers, and of course replace all the original mounting hardware with "Unbrako" bolts.
I need to get some braided line to connect the remote reservoir M/C, then at least I can roll the sucker down my driveway and see if it will work, ha ha! I've tried to attach pics for the last hour but this stupid site software here won't allow me to upload them (what's the deal, Glenn? I've reduced them down way below the max size allowed?) so I'll try again later. Cheers, Terry.  ;D
Ooh, ooh, and I FINALLY found a source for belts for my ARD's, ha ha! (I've got two MK2's with points, so I might use one on one of my bikes.............)
Offline Schultz
Re: ARD Magneto
« Reply #242 on: July 15, 2007, 12:38:00 AM »
What's your source for belts? I've had people recommend Gates before but I haven't really checked them out.
http://www.gates.com/
Offline Jim F
  • go baby go
Re: ARD Magneto
« Reply #243 on: July 15, 2007, 08:47:11 PM »
Hey Terry
what did you do with the belts that I sent over?
I think I remember  that they where too short?
They where differant than the ones for the ARDs with points
Jim
Offline cafe75-550
Re: ARD Magneto
« Reply #244 on: July 15, 2007, 10:39:21 PM »
You can also get Browning belts from Grainger. I have the part # for the MK2 CDI mag belt, if anyone needs it.
New bike!
Offline dusterdude
Re: ARD Magneto
« Reply #245 on: July 16, 2007, 10:13:49 AM »
very good belts
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline puppytrax
Re: ARD Magneto
« Reply #246 on: July 18, 2007, 04:08:55 PM »
lol
Jim
Well, it sold for the starting bid...$695USD...only one bidder...   ::)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&viewitem=&item=140137363437
IMHO, that price is over twice what it's worth, even if it doesn't need any work (and it will)...   :-\
Offline Jim F
  • go baby go
Re: ARD Magneto
« Reply #247 on: July 18, 2007, 04:54:35 PM »
they are a hot commodity these days
J
Offline Schultz
Re: ARD Magneto
« Reply #248 on: July 19, 2007, 01:51:58 AM »
That is a lot of money for one of those. I paid $350 for one five years ago and I thought that was way too much. I guess its appeal is what drives up the prices. The chopper, cafe and vintage racers all love those things.
Offline Jim F
  • go baby go
Re: ARD Magneto
« Reply #249 on: July 25, 2007, 06:52:55 PM »
They definitely get the looks and always the question
What the hell is that?
And that is my perpose of using an ARD on my Honda
almost had another for my 78 GS
RC Mag with a yosh header but it just wasn't meant to be
oh well
sigh
Big-jim
