Author Topic: HELP!! exhaust valve opening in deg  (Read 1511 times)
Offline forwheeldrift
  • 1972 cb 500 Four
    • pics
« on: October 25, 2006, 07:42:20 AM »
can any one tell me what the stock exhaust valve opening is , at BTDC
for the 72' cb 500 four
i have the original Chilton's repair book but , it dose not have the answer it says N.A.
ITS GOT THE SIZES FOR THE 750 & 750K2 BUT NOTHING FOR THE 500. :'(
Offline Bob Wessner
  • "Carbs Suck!"
Re: HELP!! exhaust valve opening in deg
« Reply #1 on: October 25, 2006, 07:48:45 AM »
From the 500/550 shop manual
  • 1972 cb 500 Four
    • pics
« Reply #2 on: October 25, 2006, 02:26:06 PM »
thank you
Offline eurban
« Reply #3 on: October 26, 2006, 04:01:28 PM »
Don't have the info your looking for but I guess you figured out that Bob gave you the valve clearance specs rather than the degree info?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: October 26, 2006, 04:17:18 PM »
So you think he was after setting cam timing? Oops. :-[
Offline oldfart
    • The Motorcycle Project
« Reply #5 on: October 26, 2006, 06:07:59 PM »
I do believe that information is still in the factory manual.  The manual gives opening and closing numbers and even the checking height.  I am on the road at present and not near my factory manual, but typically the early fours had almost all the same numbers.  Most of them were or were very close to 5-40, 40-5.  Some were 10-45, 45-10.  Like that.  I believe the 500/550 is 40-5, which means the exhaust opens at 40 degrees.  Remember however that this is using a checking height of 1mm (0.040").
http://www.motorcycleproject.com/motorcycle/text/lobectr.html
Edited because I had a brain fart and misread his question...   :)
« Last Edit: October 26, 2006, 06:43:41 PM by oldfart »
Mike Nixon
Why is there never enough time to do it right, but always enough time to do it over?
Offline oldfart
« Reply #6 on: October 26, 2006, 06:46:18 PM »
Then again, maybe he *was* looking for valve clearances...  Hmm.  In that case, friend, it's 0.002" for intake and 0.003" for exhaust.
Mike Nixon
