Author Topic: Cant find carb pieces !  (Read 666 times)
Offline seandb
« on: July 23, 2015, 09:07:54 PM »
Trying to find a accel carb diaphragm, obvious to most but the piece that is pulled when throttle is used. i broke it off trying to clean carbs a little more because bike was running rough, thought maybe dirty fuel or clogged carbs. i have found a few dif options per say but they arnt the same, looking for advice, see if i can take a piece off something sim and fix it.
Re: Cant find carb pieces !
« Reply #1 on: July 23, 2015, 09:14:37 PM »
Describe it better or post up a picture please.
When the throttle is twisted, the accel pump diaphragm post is pushed, not pulled....
Offline seandb
« Reply #2 on: July 23, 2015, 10:39:28 PM »
sorry not 100% on bikes. Its the actual rod or bolt i suppose that goes up to the throttle and attaches to the adjust screws on top with the grommet. and the bikes a 1975 honda cb750K
this is the build of it or what is looks like i guess (the rod part) but i need one that works with my bike.... could i just go to ace and find a piece that would work with it or same characteristics
Offline seandb
« Reply #3 on: July 23, 2015, 10:44:04 PM »
Here's. A better pic
Offline brewsky
« Reply #4 on: July 24, 2015, 04:41:36 AM »
This is the wrong diagram.
You are looking for the rod that lifts the slide.
I would try member "harisuluv" first.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline SOHC Digger
  • I'm not an
« Reply #5 on: July 24, 2015, 08:00:09 AM »
I have one. PM me your address and I'll drop it in the mail.
