Author Topic: Wire sleeving ?  (Read 430 times)
Offline jchabino
Wire sleeving ?
« on: July 24, 2015, 09:22:29 AM »
 Hello all,
On my 76 550 there are two wires that run from the clutch lever down the outside of the  handlebars and somewhere in the harness.  What are these wires for ?  I want to cover them with sleeving.  Cycle terminal has sleeving in 11/32' 3/16, 1/4' 5/16' etc.  What size sleeving should I use?
Tnx,
Jerry
Online calj737
  • I refuse...
Re: Wire sleeving ?
« Reply #1 on: July 24, 2015, 02:52:59 PM »
Clutch safety switch. Requires clutch to be pulled into start bike. Should be basically 2 18AWG wires. 3/16" works fine.
Offline jchabino
Re: Wire sleeving ?
« Reply #2 on: July 26, 2015, 06:54:44 AM »
Thanks Cal.  Much apreciated.
Jerry
DH
Re: Wire sleeving ?
« Reply #3 on: July 26, 2015, 07:40:48 AM »
Related to sleeving size, does anyone know what size the sleeving is at the end of the main harness?
(At the frame neck end) It's larger than any sizes listed/available from either cycleterminals or vintageconnections.
Any other sources to get it from?
