Author Topic: Need to clean your carbs? Or anything else?  (Read 1807 times)
Offline pmpski_1
  • Beast V and Beast I
    • My CB550 related blog on MSN Spaces
« on: May 27, 2005, 12:23:02 AM »
How about an ultrasonic parts washer?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=11809&item=7518563792
Looks like it needs a lot of electricity to run.
Beast   I: 1974 CB550K
Beast IV: 1976 Chevy Blazer
Beast  V: 2003 Buell XB9S
Offline Steve F
Re: Need to clean your carbs? Or anything else?
« Reply #1 on: May 27, 2005, 04:43:05 AM »
Only 4 amps according to the specs.  That's about what a television uses.  This ultrasonic cleaner doesn't have a tank, so you'll have to come up with something to mount the transducer to.  I have a small benchtop ultrasonic machine at home that I picked up from work since they weren't using it any more.  It works OK for some things, but can be totally useless on others.  It depends on the solution you dip things in. I tried using it to clean carbs, and wasn't satisfied with the results.  You can't use flammable solutions in this thing, so the available effective cleaners were out.  From my experience, water based solutions just don't work on carbs.  I cleaned the whole wire loom with the ultrasonic, and some bearings, and that worked well.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #2 on: May 27, 2005, 05:39:48 AM »
I'm afraid not many of us have 440V single phase supplies hangin' around...
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline pmpski_1
« Reply #3 on: May 27, 2005, 10:54:10 AM »
Yah, that's one of the reasons I didn't jump on it :)
