Author Topic: RE: Want an easy way to remove casting marks from CB750 hubs & other aluminum  (Read 990 times)
Offline chewbacca5000
  • I polish covers!
Hey Team,
Looking for an easy way to remove the casting marks from CB750 hubs and other aluminum.  I am doing quite a bit of polishing on my current project and it is taking hour after hour of tedious sanding to get to smooth aluminum.
I noticed that even when glass beading the casting marks remain.  They are like tiny, little dimples that very similar to what happens when aluminum oxides.  In order to get a show polish this stuff needs to be fairly even.
Looking for something better than sandpaper.
most folks start with sandpaper too fine.   You will sand your fingers off with 400 grit.  Sart with a file on the big nasties, then 100 grit on up...
Dremel is a good start then work your way QUICKLY down to sandpaper.
Machine the fins off..smooth look...
Online Don R
Lathe the round parts.
Offline Garage_guy_chris
When i did the polishing for my 750 i decided to mess around and find a better way. In the end about the best way i could find was one of these oscillating sander multi-tool things. I started at about 120 and worked up to 400 then went to red scotchbrite then on to the wheels and polishing compounds.
http://d3ka0sx7noujy3.cloudfront.net/wp-content/uploads/2013/02/best-sanders-fein-multimaster.jpg
  • I polish covers!
I used the lathe for the tappet covers and it was an improvement.  Really want to do the hubs with the lathe, but need a bigger chuck to hold them.
I wonder if the 3m bristle brushes would help?
Offline calj737
  • I refuse...
Chewy - mount the hub to a spindle, then chuck the spindle in your lathe. A flat piece of steel, bolt pattern drilled, then a tube welded to the flat piece. Chuck the tube. Voilá!
If you opt to sand, use green scotchbrite pads to start in a dremel, rotary grinder, angle grinder. It's more than coarse enough. Then progress to red, then to grey. Then start wetsanding before buffing.
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
  • I polish covers!
This is how I did my front hub
http://forums.sohc4.net/index.php/topic,58276.msg631146.html#msg631146
Thanks for the tip Bill!  Did a front hub quick and easy.  Very simple to wrap the wire around the axle and put into the lathe.  I used the bolt holes so I can polish both lips without changing position.
Yours looks sweet, but I don't see the point in polishing the speedo or brake area as they are covered.
Thanks to you too Cal.  I might make a fixture done the road or not.
Frank don't have enough room to cut off fins for rear hub, but can do front when my new chuck comes in.
  • I polish covers!
This worked out pretty good.  For those without a lathe or drill press you could do the rear hub with 2 20mm pillow blocks, a 20mm pulley and a motor.  Any 1/2HP or better will do.
