Author Topic: Air bubble in tank paint mean hole in tank?  (Read 8157 times)
Offline BollarNPS
« on: July 24, 2015, 05:13:23 PM »
I have been cleaning the inside of my tank out to get rid of the rust. Finally got it looking brand new and went to get some denatured alcohol to put in to assist with getting rid of water. I then put gas in the tank and swashed it around to coat the metal with gas. I then noticed an air bubble in the paint that i do not believe was not there before. I can push on the bubble but it then returns to size. Thought about poking a needle hole in the bubble to get rid of it. Before doing so i thought i would see what you guys thought. Thoughts??
Offline Bodi
Re: Air bubble in tank paint mean hole in tank?
« Reply #1 on: July 24, 2015, 05:24:18 PM »
I have to say that's a hole in the tank. Can't think of anything else that would make a bubble like that.
Offline BollarNPS
« Reply #2 on: July 24, 2015, 05:28:59 PM »
well shoot. so i either need a new tank or to have the tank lined? Any suggestions on which tank liner just incase a new tank is to expensive.
« Reply #3 on: July 24, 2015, 05:30:22 PM »
 This not be good kimosabe. There was a thread recently for liners, maybe someone can provide a link.
Offline Powderman
« Reply #4 on: July 24, 2015, 05:41:40 PM »
And a repaint. I would strip it clean and weld up any holes you find before sealing and painting.
Offline triple
« Reply #5 on: July 24, 2015, 05:43:34 PM »
I think most commercial liners are quite good now days.
I recall a product " POR 15 " being of good value. I think  this is what I used on a Norton tank approx. 15 years ago and no issues since.
Cant recall where I got it from but it did come out of the states
Offline BollarNPS
« Reply #6 on: July 24, 2015, 05:51:43 PM »
yeah i mean heck there is only one way to learn how to do something. Im not super good at welding but i could use some practice. I was planning on stripping and painting tank anyways. How do i weld the tank though? Do i cut a small area out and put a larger piece that will cover the hole i cut on the inside then weld that. Just curious on how to weld and not leave a sheet metal sized bump.
« Reply #7 on: July 24, 2015, 06:02:17 PM »
Best to take it to a pro, and practice on a scrap tank.
Offline BollarNPS
« Reply #8 on: July 24, 2015, 06:06:24 PM »
yeah im not gonna try to weld my tank. Ill probably just seal it.
« Reply #9 on: July 24, 2015, 06:10:14 PM »
Take some beer to a radiator shop  ;D
Offline triple
« Reply #10 on: July 24, 2015, 10:58:58 PM »
On rusty ( ing )  tanks you may  well be better off with the tank lining method.
Od tanks which show rust holes normally have surface rust elsewhere in the tank. If you don't neutralise and seal it you may find small parts of rust end up in your carbs..... you know where this will take you..
All tank lining kits I have used in the past come with a cleaning and rust neutralising solution and then the 2 part sealer.
Just welding the existing hole may lead to other holes opening up a little further down the path only to destroy your new paint job and then to do it all over again...
Offline Johnie
« Reply #11 on: July 25, 2015, 07:03:16 AM »
Not good...been there with my red KO. Ended up having it painted 3 times to get it right. I think the etching from the liner prep and the sanding by the painter just got the tank to thin. Pin holes showed up just south of the gas cap. The last time I had the liner removed and the top of the tank silver soldered. New liner installed and all is well. I could have bought a different tank, but since the bike was my first 750 I wanted to keep all the parts on it that it was born with. Good luck with it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Cougars750F0
« Reply #12 on: July 25, 2015, 08:39:26 AM »
You mentioned that you cleaned out the rust did you use Ospho or another product that kills the rust? If not the rust could come back and grow between the liner and paint. if you are going to repaint don't sand it off but instead strip the paint off sanding can thin the metal down. I've had good results with Aircraft brand paint remover. I agree with calj737 remove the paint first so you can see if there are any other issues that you need to address before you line the tank this is a common problem I have had to get another fuel tank  after I removed the paint you never know what you'd find. Make sure you you use a paint that will handle gas spills after all that work ;D Good luck with your project.
1970 Honda / Yoshimura 810 with ported head, 1968  Honda CB450 5 speed European model, 1973  Triumph Bonneville 750 twin carburetor model, 1975 Honda 750F0 Super Sport, 1977 Honda 750A
Offline nvr2old
« Reply #13 on: July 25, 2015, 09:35:09 AM »
If it were my tank, I would strip it to bare metal, tig weld the pin hole, grind it smooth and then line the tank.  If the liner doesn't adhere perfectly, you'll have the same problem popping up again unless it's welded.  Real simple to have a quick spot weld done.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline BollarNPS
« Reply #14 on: July 25, 2015, 09:45:51 AM »
I'm going to remove paint first with aircraft removal stuff. Then I'll see what it cost to have it welded as I don't want to blow my head up. Then I guess I'll try the caswell. Thanks everyone
Offline Tews19
  • I am no
« Reply #15 on: July 25, 2015, 10:56:08 AM »
With Caswell, pinholes cover/fill completely so you can skip the welding. But to weld it up is a better fix before the liner.
Very true. My 550 F tank has around 30 pinholes on both sides. Sealed it with Caswell and not one issue since.
1970 Honda CB750 survivor.
Offline BollarNPS
« Reply #16 on: July 25, 2015, 11:00:06 AM »
I've read a lot of negative reviews with liner caswell having the least amount. Is it really that easy to mess up or are these people just not following directions?
Offline Tews19
  • I am no
« Reply #17 on: July 25, 2015, 11:10:30 AM »
Follow directions. My tank was as dry as one could be from the factory. Mix and pour. Than keep turning until all sides are covered. Let sit than use. I was so nervous I went to my buddies to do it. He is an older fellow who mixed it and poured it in. It's that simple. Best 40 or 50 bucks one may spend on a tank.
Offline przjohn
« Reply #18 on: July 25, 2015, 12:46:17 PM »
Another vote for the Caswell Kit. Never had a problem with the stuff. I am also in the camp of repaint and line it.
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #19 on: July 26, 2015, 02:03:45 PM »
metal water and gas tanks of all sizes and metals have been getting repaired just fine with either silver or bronze braze for close to a hundred years.  easy to 'flatten' when done prior to paint also.  using acid for these tank cleanings is a real risk since acid doesn't discriminate between rust and ok metal.   you are far better off using a reformer that only attacks rust and follow up with a corrosion inhibitor.....no more flash rust to mess with your tank liner.  my second choice would be electrolysis followed up with a dose of reformer and then the inhibitor.  And then you can use the PQR 15 that is sold in just about every auto supply in the US for cheap money.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Offline Short shins
  • New Zealand
« Reply #20 on: July 27, 2015, 12:54:22 AM »
Sadly a bubble in the paint means a hole.. :'(
in my case the previous "restorer" rather than fix the problem just lined the tank, slapped a layer of bondo and some paint. looked nice and worked well until I noticed some paint lifting and then it escalated to a slight weep of fuel
Whole Right hand side...I think the liner and paint was holding it together
I had a go at fixing it with some epoxy Tank repair kit didn't really work. Needs stripping out welding/soldering and a repaint,
or I just buy a "new" tank from Wobbly.. :) Sorted!
I love sleep. My life has the tendency to fall apart when I'm awake, you know?”
Ernest Hemingway
Offline lrutt
« Reply #21 on: July 27, 2015, 05:13:00 AM »
check the rest of the inside of the tank. If there is a lot of other rust then lining is probably your only option. If it's localized though. I'd suggest gently dimpling in the tank in that area, sanding down to bare metal, and soldering over that hole, you can then touch up with bondo to smooth it out.
I really hate liners as it seems it always a matter of if not when they decide to separate and fail.
Offline Powderman
« Reply #22 on: July 27, 2015, 07:15:36 AM »
Don't you mean "When and not if"?
« Reply #23 on: July 27, 2015, 08:49:53 AM »
Try to get a bore scope in there and see the really condition... If it's only a few holes, I would probably just try to fix them.. Rather than liner..
Offline nvr2old
« Reply #24 on: July 27, 2015, 09:41:12 AM »
Another alternative is to take the tank to a radiator repair business.  They can clean the inside beautifully, repair the pin holes and pressure test it for you, too.  I've done that several times with good success.  It will ruin the paint, however, but if it's going to be stripped and re-done anyway..might be a good choice.
