Author Topic: Compression Test?  (Read 964 times)
Offline Bee Joenz
Compression Test?
« on: July 26, 2015, 11:20:38 AM »
Hey guys -
Just a quick question: I have a friend doing a compression test on my 77 cb750 F and he's getting a reading from left side 1 = 90 pounds and 2, 3, 4 = 60 pounds. I know that they're all supposed to be at 170. Curious as to whether this will require a rebuild/replacement of the engine or what exactly.
Any and all suggestions would be greatly appreciated.
The engine is being tested with the carbs on but again my concern is the fact that the pounds are so low in the first place.
Thanks
Offline Johnie
Re: Compression Test?
« Reply #1 on: July 26, 2015, 11:26:25 AM »
Are you doing the test with the carbs wide open? Would help to let us know a bit more about the motor like how long it was sitting. How many miles? Many times the rings are just a bit stuck and once you do the 3,000 mile tune up and ride the bike they will free up and compression will rise.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #2 on: July 27, 2015, 06:59:47 AM »
Dont sweat the 170 either, it depends on the tester a lot.
Important is to have values within 10% and daily ridden bike will have better values than a fresh barn find.
