Author Topic: Wrist Pin Cir Clips  (Read 1044 times)
Offline rundogdave
Wrist Pin Cir Clips
« on: July 29, 2015, 07:47:23 PM »
How does one remove the wrist pin retaining clips? A special tool. I afraid I'm going to mangle the pistons using a screw driver, or something similar.
Offline Davez134
Re: Wrist Pin Cir Clips
« Reply #1 on: July 29, 2015, 08:14:04 PM »
First off, make sure you totally cover the holes in top case so that the clips do not fall in. Second, they should not be reused, so don't worry about bending when removing. I just use a very small flathead screwdriver to pry out of the groove, then I push pin out that side, then remove other clip with piston off rod.
Offline rundogdave
« Reply #2 on: July 29, 2015, 08:59:31 PM »
I'm going to bore it anyway, so I guess I shouldn't worry about buggering up the pin hole. Those clips are just so small for my 54 year old eyes to see! Gonna need to get a finer tip screw driver as well.
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #3 on: July 30, 2015, 06:32:26 AM »
Dental pick
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Offline rundogdave
« Reply #4 on: July 30, 2015, 05:03:04 PM »
Offline eigenvector
« Reply #5 on: July 30, 2015, 05:18:53 PM »
I used a hose pick.  If they've been in there a while (likely) those wire clips can be pretty hard to budge.  Put on goggles, they make excellent projectiles.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline rundogdave
« Reply #6 on: July 31, 2015, 05:47:51 PM »
Hose pick?
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: July 31, 2015, 05:49:16 PM »
- John Augustus Shedd
Offline Garage_guy_chris
« Reply #8 on: July 31, 2015, 06:09:54 PM »
I just use a mini pair of needle nose pliers so i can grab them otherwise they go flying
