Author Topic: Fuel Gauge not working  (Read 1685 times)
Offline mdl91881
« on: July 30, 2015, 06:18:20 PM »
Does anyone have any info on how to test the fuel gauge sending unit? My gauge doesn't seem to be working. i hooked it up and manually moved the float and dont get anything at the gauge.  Not sure how to tell if its the gauge or the sending unit that is bad.  Have never had the bike on the road how accurate is the fuel gauge, is it even worth replacing it?
Offline jukku
  • Happy with my Hondamatic
Re: Fuel Gauge not working
« Reply #1 on: July 31, 2015, 08:51:40 AM »
Test the sender with a ohm-meter, empty X ohm and full Y ohm. Test the 7V regulator with a voltmeter, should be about 7 volt ::).
Offline stikman
  • Bit of an
« Reply #2 on: August 12, 2015, 06:07:51 PM »
Fill up, set your trip meter, ride til it's empty.  Now you know how far you get on a tank.  Just set your trip meter at each fill up or simply watch your odometer... all I do, and I only get 54 miles to a tank.
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline mdl91881
« Reply #3 on: August 13, 2015, 04:58:33 AM »
Thanks, thats what I do with every other bike I have, I just thought it would be cool to have it working.  54 miles per tank? that seems very low to me
Offline dave the welder
  • dave the welder
« Reply #4 on: August 14, 2015, 10:31:12 AM »
he's not using a stock tank. i get 140 or so before i use reserve
don't buy it build it
Offline stikman
  • Bit of an
« Reply #5 on: August 14, 2015, 05:50:36 PM »
Yeah sorry, mine's a 2 gallon tank.
