Author Topic: The Hot Mess - 1975 CB550F1 Frame/1981 CB650 Engine  (Read 130278 times)
Offline MessnerMoto
Re: The Hot Mess - 1975 CB550F1 Frame/1981 CB650 Engine
« Reply #25 on: August 03, 2015, 05:27:06 AM »
The Cognito hub is heavy because it's not hollowed, and it's run on a 3-axis CNC. He knows this, but without significant changes in the machining time, the weight can't be reduced. And, there is the liability aspect of making aftermarket critical parts for mass buyers who are making modifications. So I would not get hung up on the weight aspect as it tends to equal out with modern discs (much lighter) compared to stock cast iron rotors (heavy) and the stock caliper.
It all depends of what do you want to achieve in your build. Cognitomoto hub is fast and cheap solution. But I am trying to improve performance also. Lowering unsprung weight at front by ~1.5kg will noticably improve handling.
Yes, Messner, I am pretty sure about the TTR400 swingarm.  Not only is it a great deal from a good member friend, I am a fan of the boxed-style swingarms.  I have a different style boxed swingarm going on my CB750K2 project right now.
TTR400 swingarm probably weights less then stock swingarm and is more stiff...
« Reply #26 on: August 03, 2015, 08:55:38 AM »
There was a good 3-4 month gap between pulling the engine from the frame and commencing disassembly.
During that time the remnants of the oil had time to seep down to the pan.
If you have a weak stomach, avert your eyes.  This is not pretty.
Looks like you should save that for the Sunday roast ???. Hope the rest of the unravelling presents a little kinder.
That type of engine "gravy" would taste very good.
« Reply #27 on: August 03, 2015, 08:56:49 AM »
What did you do with the 650 tank?
Unfortunately, it was rusted through on the bottom.  I am planning to use some thing different anyway.
« Reply #28 on: August 03, 2015, 09:06:55 AM »
No problem, Cal.  Those were all interesting points.
I think that with an aluminum rim, elimination of the stock seat, swapping the swingarm and other changes will all result in a net loss of unsprung weight.
NOTE: To all 650 engine rebuilders, the 650 uses 10 shorter cylinder studs and 2 longer studs -- as opposed to the 550 using 6/6.  The APE Heavy Duty studs will fit, but you need to buy another package of them to get the right number of short/long studs.  Stock studs/bolts -- especially the two long ones -- are more difficult to come by.  There is an ebay seller with one (not enough) left.  http://www.ebay.com/itm/201397804617?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT  Since I am increasing the compression on this engine, I am not inclined to re-use the old ones, and I'd rather use the APE heavy duty studs.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #29 on: August 03, 2015, 09:19:18 AM »
Awesome concept Don. It's pretty tough to beat the smile off the face of a 550 rider and one with a strong torquey motor will be tougher yet. Sorry to hear about the initial findings. Hope the surprises stop there.
Cheers
FJ
« Reply #30 on: August 03, 2015, 09:21:30 AM »
I agree that changing those items will result in a net lower weight. I fabbed up some of the bits of the boy's 500 aluminum seat hoop this weekend. Cut the stock subframe off completely. Weighed the two, the new subframe is 4.2# lighter overall, 1/8" thick wall, billet 6061 tubing. Comparatively, it's probably 4x stronger and over 4# lighter. It will be interesting to compare the swing arms when that's done too.
Did you ever re-weigh the stock hub? I'm curious what you find...
I did not weigh the stock hub, since it's still laced up and on the rolling chassis.  I think my post was a little muddy.  I just weighed the Cognitomoto one.  I assumed it was lighter than the stock hub, in making the statement above, but it looks like I'm wrong.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #31 on: August 03, 2015, 09:29:22 AM »
You're on the right track Don. Reduction of unsprung weight has a significant effect on handling and performance but weight removed furthest from the centre of rotation makes the biggest difference.
« Reply #32 on: August 03, 2015, 10:01:17 AM »
Calling all 650 parts hoarders:
I am looking for a cam chain guide for a 79-82 CB650.  I cannot find any NOS ones with the on-line dealers (including David Silver and CMSNL) and nothing on Ebay.  Mine is looking pretty worn (with cracks in the rubber)
The part number is Honda 14611-426-010
Here's a NOS one that sold on Ebay for about $8!!  I wish I knew about that listing!
_57_zpsbbs7f6yx by Donald Leonhardt, on Flickr
The part is #7 in the fiche below:
cam_zpshotrykaq by Donald Leonhardt, on Flickr
If you have a good condition spare and it's for sale, PLEASE let me know.
This part is almost as rare as . . .
sasquatch by Donald Leonhardt, on Flickr
Don
PS - I already PM'd Bill Benton and rb550four.
« Last Edit: July 03, 2017, 10:02:32 AM by SOHC4 Cafe Racer Fan »
« Reply #33 on: August 03, 2015, 11:51:40 AM »
Ping Brent too. He may know of a secret, race derived option (Shhh!)
That Brent is a crafty guy! I PM'd him at your suggestion.
Here's how my weekend closed out:
Got the crankcase split apart on the donor 1982 CB650 engine.
Good news:  Surprisingly, the crankshaft and transmission are just fine!!
image_zpsm1m6jcn5 by Donald Leonhardt, on Flickr
More sludge in the case:
image_zps3ly26pn5 by Donald Leonhardt, on Flickr
« Last Edit: July 03, 2017, 10:13:28 AM by SOHC4 Cafe Racer Fan »
Offline rb550four
« Reply #34 on: August 03, 2015, 03:00:18 PM »
Where did you find the missing chunks? Did they manage to make it to the pan without hitting anything?
How bad did that piston  look?
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #35 on: August 03, 2015, 04:13:37 PM »
I'm following this one.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
« Reply #36 on: August 03, 2015, 04:20:44 PM »
RB,
Here's the weird thing about it.  No metal in the oil pan or lower cases, just gravy/sludge.  The pistons had no damage -- just normal carbon build-up -- and the rings were intact.  There were signs that the pistons had at one time been seized in the cylinders but they moved free when I bought the bike.
As crazy as it sounds, it appears that a PO took the motor apart after a catastrophic failure and/or the pistons seizing, cleaned it up quickly (removing broken metal from the cylinder sleeve), slapped it back together and re-filled the engine with new oil.  I know that sounds pretty messed up, but I cannot otherwise explain it.
« Last Edit: August 03, 2015, 04:39:27 PM by CB750 Cafe Racer Fan »
« Reply #37 on: August 03, 2015, 04:42:24 PM »
Sorry Don, I have no spare 650 bits. I PM'd with a lead though.
I just weighed a 550 rear hub, unfortunately it won't mean much because it's complete except  there's no sprocket, and no brakes or brake plate.....11.5lbs.
« Reply #38 on: August 03, 2015, 04:44:59 PM »
Thanks, Brent!
Offline riverfever
« Reply #39 on: August 03, 2015, 04:45:48 PM »
Don have we arrived at the point where we are posting random comments and/or pics in this thread yet?
Offline P.abrera
« Reply #40 on: August 03, 2015, 04:55:12 PM »
Ooyeh! I like where this is goin. Onboard for this one giddyap!
« Reply #41 on: August 04, 2015, 03:29:05 PM »
I spoke with Mike Rieck today.  He echoed the advice I received from Brent Waller and Cal regarding an aftermarket cam.  I'll be packaging up my 650 cam for a Megacycle hardweld 126-20 and hardweld rockers!  Mike said that the CR26s would probably work best since this is being built for street rather than top end race performance.
It's a good thing because the camshaft out of the donor motor had some VERY minor wear.  Probably not enough to cause issues, but the hardweld will rectify that.  Jeez, almost everything in this donor engine is crap-ola except the crankshaft and transmission!
Offline knottedknickers
« Reply #42 on: August 04, 2015, 05:34:22 PM »
I just weighed my 750 hub (bearings and spacers on; rotor and speedo unit off) and it came in at 3 lb 4 oz = 52 oz = just less than 1.5 kg (on a Braun analogue kitchen scale). For what it's worth...
CB750 K6 http://forums.sohc4.net/index.php?topic=141388.0
The plural of "anecdote" is not "data" (Borgmann 2002:5).
« Reply #43 on: August 04, 2015, 06:07:24 PM »
And a Cognito hub with modern floating rotors and an aluminum rim are likely much lighter than the stock hub mounted to the heavy stock steel rotor and steel rim.
« Reply #44 on: August 04, 2015, 06:36:53 PM »
Oh, front hub.... ::)
« Reply #45 on: August 04, 2015, 07:38:58 PM »
Well, even the crankcase from the 1982 donor motor have proven to be CRAP-OLA.  After clearing away the sludge/gravy on the top crank-case, what to my horror should appear?
This . . .
image_zpsjfha0gen by Donald Leonhardt, on Flickr
Which should look like this . . .
image_zpsg8wljctm by Donald Leonhardt, on Flickr
But, instead, looks like this . . .
image_zpsa2mcvhf9 by Donald Leonhardt, on Flickr
So let's recap, shall we.  Stripped threads on the head, minor scoring on the camshaft, a few bum rockers, cracked cylinder sleeve, and hole in the crankcase!!!
I know I could JB Weld it, but LUCKILY, I purchased a spare, clean 1981 matched set crankcase from Ebay just before I found the donor bike, and the bearing sizes match BBBB.  The only issue with the 1981 crankcase is that it has a stud/bolt broken off just a 1/4" or less from the crankcase.  It's being extracted by a machine shop and hot-tanked but then I should be okay to start anew.  DRAMA . . . averted!!
Oh and my cam chain guide has 3-4 width-wise cracks.  Honda Part No. 14611-426-010 is no longer made and I cannot find one anywhere.  Of course someone just sold a NOS one 2 months ago on Ebay for only $15!!  And then another NOS one in February for $8.  Now the NOS ones are unobtainium.  I'm in the hunt for a good condition used one. . . .
« Last Edit: July 03, 2017, 10:25:30 AM by SOHC4 Cafe Racer Fan »
Offline riverfever
« Reply #46 on: August 04, 2015, 08:37:31 PM »
So if I understand correctly...you're gonna combine the 81 with the 82 and then you should be ok? Sorry you're having so many issues right out of the gate Don. You'll get it sorted man. Hang in there.
« Reply #47 on: August 04, 2015, 08:45:22 PM »
So yes, it's a combination of a 81 crankcase with 82 top end parts, crankshaft and transmission capped off with hard welded 82 camshaft and rockers.
« Reply #48 on: August 05, 2015, 12:09:11 PM »
Great news on the cam chain guide.  On a recommendation from rb550four, I reached out to Tom Witt aka witttom on the CB650 forum.  He graciously offered a good condition used cam chain guide at a better-than-fair price.  So glad to get that sorted out.  The NOS ones are rarer than hen's teeth!
Now the wait for my order for NOS valve guides, cam/rockers to go out to Mike Rieck to Megacycle, the cam chain guide from Tom Witt and the machinist to remove the leftover bold from the crankcase.
Things to do:
I am going to figure out what I want to cut off the frame, where to reinforce, and weld a frame hoop, rearset mounts, new tank mounts, etc.
Here's what someone (can't remember who) suggested a ways back:
Framegussets_zps50735415 by Donald Leonhardt, on Flickr
And I also need to figure out what size 18" rim to buy for the front, and what do with the rear wheel.  I am thinking of adapting a 750F or newer rear disc brake.  I would welcome your thoughts on what rear disc brake adaptations people have made with the 550.
« Last Edit: July 03, 2017, 10:18:46 AM by SOHC4 Cafe Racer Fan »
« Reply #49 on: August 05, 2015, 01:20:33 PM »
The rear will fit a 150 comfortably. You'll need to think about clearance of the brake stay rod if you end up sticking with a drum brake.
What front end are you planning? GSXR? If so, I'd go up to the 18x3.50 for a 120-18 tire.
Why not grab new bronze valve guides from Dynoman?
Good to know as to tire fitment.
Yes, the front is a 2007 GSXR600 I might go with the 120/80-18 instead of the 110/70-18.
Unfortunately, the bronze valve guides from Dynoman do not fit the 650 (according to Buzz), only the 500/550.  Buzz says that the only compatible part he sells are the valve seals.  :(
