Author Topic: HD Wheels  (Read 936 times)
Offline rundogdave
HD Wheels
« on: August 03, 2015, 01:52:04 PM »
I'm not sure if I should ask this here, or how it will be received, but here goes. Can Harley wheels be put on CB750 lower legs, or on the rear for that matter? If so does anyone have any experience doing this? Does anything need to be changed? Axels, bearings??
Offline Cqyqte
Re: HD Wheels
« Reply #1 on: August 03, 2015, 02:47:24 PM »
Yes with bushings HD wheels can be used on metric bikes.  I have done it many times for less than $50 - $75 a wheel.
Offline rundogdave
Re: HD Wheels
« Reply #2 on: August 03, 2015, 07:56:11 PM »
'78 750. I don't have specific wheels yet. I guess the front is the main concern. I'm going to put a weld on hard tail section, so I can order the rear section how ever I want it.
Re: HD Wheels
« Reply #3 on: August 03, 2015, 08:10:18 PM »
Most rear wheels from big twins into at least the 90,s and maybe still are 3/4 inch.  A smidge smaller than a 750 axle..less than a mm difference..so you should be good to go..
 Mostly 5 bolt stuff and usually dished sprockets..  And Timken tapered bearings.
Offline dusterdude
Re: HD Wheels
« Reply #4 on: August 04, 2015, 04:19:30 PM »
Correct,harley went to a 1 inch?axle around 2000
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline turboed13b
Re: HD Wheels
« Reply #5 on: August 04, 2015, 05:04:52 PM »
Harley uses 3/4in, 1in, and 25mm sealed bearings in 2000+ years so none of those will work.
Offline Cqyqte
Re: HD Wheels
« Reply #6 on: August 04, 2015, 05:18:37 PM »
A 1978 CB750 uses a 17mm front axle so you will need to get yourself two conversion bushings made to go from 17mm ID to 25.4mm OD to fit into a 1" HD bearing wheel, or machined to 25mm OD to fit an ABS 25mm bearing Harley wheel.
Re: HD Wheels
« Reply #7 on: August 04, 2015, 11:45:05 PM »
Just find a bearing with 17mm Honda ID and the Harley bearing OD... ;)
Offline hotdog
Re: HD Wheels
« Reply #8 on: August 04, 2015, 11:53:55 PM »
The "Wrenchmonkeys" have built a few cb's running fatboy 16" wheels....
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
Re: HD Wheels
« Reply #9 on: August 05, 2015, 02:23:38 AM »
I don't mind those wheels on the right build...
