Author Topic: Greetings from BC Canada! Bought my buddies 1980 CB650C, some issues...  (Read 465 times)
Offline Icewolf
Hello CB650ers! I recently purchased my buddies 1980 CB650C, it hadnt ran in a couple years, so I did the valve timing, checked the air/oil filter and changed the oil. After a little while the bike started having a hard time running at idle and would die after a few cycles through each cylinder at idle... I took the alternator cover off and about an inch worth of crud and shyte from the alternator rotor fell out... so i'm thinking thats the problem, I have to check the charging system with a multimeter still. My other, bigger issue is the front brake is leaking fluid like crazy, I took it apart and there is a lot of surface corrosion on the housing, and the piston isnt too hot either, they are beyond serviceability. So my question is: Does anyone around here know of a supplier that would have a front brake for my bike, OEM or otherwise? Also does anyone else have recommendations for things to do to make sure the bike is in tip top shape?
Thanks!
What part of BC are you in?
