Author Topic: Front Fork Lock Replacement - 1974 CB750 - Help Needed  (Read 2802 times)
Offline RRRToolSolutions
  • I love old Japanese bikes!
« on: October 26, 2006, 10:03:43 AM »
I have looked through several sections of my Honda factory service manual, Honda's general service manual, but I cannot find where it explains the front fork lockset removal and installation. I just bought a NOS lockset from Western Hills and will be very happy about needing to carry around only 1 key.
Help/input appreciated.
Regards,
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline Bob Wessner
  • "Carbs Suck!"
Re: Front Fork Lock Replacement - 1974 CB750 - Help Needed
« Reply #1 on: October 26, 2006, 11:40:09 AM »
If it hasn't changed from the earlier locks, if you have a key for the lock you want to remove, insert the key, turn it to the unlocked position and the lock mechanism should slide out after removing the screw.
« Reply #2 on: October 26, 2006, 12:45:19 PM »
Bob, thanks. I bet there is no key.....
Offline Jonesy
  • Shop Rat
« Reply #3 on: October 26, 2006, 12:48:02 PM »
If it is in the unlocked position, you can just pull it free with needlenose pliers after removing the screw and plastic cap.
Offline Weatherman
« Reply #4 on: October 26, 2006, 01:31:31 PM »
Just did this myself. Pulls right out. Be careful not to loose the little spring.
« Reply #5 on: October 26, 2006, 07:06:12 PM »
Hey guys, it worked. I had a T1796 key which matched the number on the lock. It's odd though, I had to file down the sides of the key because it was too thick/wide to go into the steering lock. once I thinned it to .070 it went in. I guess the newer factory pre-cut keys are thicker. The lock turned to the left and pulled right out like you told me it would --
Thanks again.
Regards,
Gordon
Offline mcpuffett
« Reply #6 on: October 27, 2006, 10:30:13 AM »
them locks are like rocking horse poo  :D, so don't lose it  ;),   mick.
