SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
cb550 oil pump replace = fill up with oil?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: cb550 oil pump replace = fill up with oil? (Read 436 times)
BigBird
Full Member
learning and doing
on:
August 06, 2015, 03:54:31 AM »
Hi
I´ve inspected my oil pump and everthing seems fine, but then again i don´t know exactly what to look for.
I have a question upon mounting the oil pump again, if i should fill it with oil or anything?
cheers
Logged
DaveBarbier
Really Old Timer ...
Re: cb550 oil pump replace = fill up with oil?
Reply #1 on:
August 06, 2015, 05:31:28 AM »
I would fill it with oil and try to slap it on without much spilling out. When you're ready to start it up, use the starter with the kill switch and fuel petcock off and crank it over until your oil light goes out to get pressure up and oil in the top end.
Logged
Patina Hyena - 550/650 674cc Hybrid Cafe Build
The Mayor - ‘79 CB650 Factory Revive
Need a full oil pump o-ring kit for your 650?
Want to use a Dyna S ignition on your 650?
BigBird
Full Member
learning and doing
Reply #2 on:
August 06, 2015, 07:20:44 AM »
will do that, thanks!
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
