Got some new wheels and tires. US Mags Bandits, 17x8 / 4.50" backspacing / $165 ea from JEGS, 17x9 / 5.25" backspacing / $172 ea from JEGS, 245/45 General G-Max front tires, 285/40 Continental Extreme rear tires. Looks good, kinda like retro Pontiac wheels, and with the bigger rear tires and wheels, gives me the stance I was looking for, with a very slight forward rake.
Had an interesting chat with someone at a car show I was at. Older couple comes up and asks me if that was my truck, I said "yes", and they said they used to own it! Gave me a bunch of info on the truck that I didn't know. The original owner (he was the 2nd owner, and knew the guy) did the V8 conversion when the truck had 4K miles (it has 74K now), so the conversion's been running now for over 10 years. The aluminum driveshaft, water pump, and electric fan are fairly new, and the fan is designed for an RV, so it flows a good amount of air for a single fan. Also, it's an LT1 that was rebuilt to LT4 specs at the time of the conversion, and puts down about 360hp at the wheels, with similar numbers for torque. Said it's got close to 400hp at the crank, and ran in the 12's in the quarter mile. It's got a more radical cam than an LT4, so it has a lumpy idle, and helps the truck to pull really hard in 2-3-4-5 gears. He's glad to see it went to a good home!
