Author Topic: Carbs leak on kickstand  (Read 4892 times)
Offline Mantree
« on: August 10, 2015, 09:21:52 AM »
So I have long sense been in the habbet of shutting off my fuel when parking but this morning my bike started puking gas while on the side stand running it don't start leaking right away but when it dose it is a waterfall and don't leak when upright
Sent from my SM-G900V using Tapatalk
Offline Djfob
Re: Carbs leak on kickstand
« Reply #1 on: August 10, 2015, 09:25:08 AM »
Possible a sticky float or something blocking the float valve and seat
78 CB750k
« Reply #2 on: August 10, 2015, 09:27:55 AM »
+1
clean your tank
Clean your carbs
Offline Mantree
« Reply #3 on: August 10, 2015, 11:25:39 AM »
Ya hats what I was thinking it say all winter so I might have some varnish but I do have a inline filter on the fuel line so it's not dirt or rust from the tank I have had that before so I always run a filter
Offline Restoration Fan
  • My wife will never call me
« Reply #4 on: August 10, 2015, 04:55:13 PM »
Well if my carbs were leaking on the kickstand, I would probably just take them off the kickstand!
LOL...sorry couldn't resist.
Offline Patrick
« Reply #5 on: August 10, 2015, 05:36:04 PM »
I'm thinking you have a problem with your float bowl gaskets. If they aren't sealing, the gas would never get high enough to close the needle valve, and the gas would just flow. And the carbs should not leak on the sidestand unless it is coming from the bowl seam. You might have kinked one when you put the carbs back together. It also would interfere with the float.
Worth a look anyway. Sounds like the carbs must hit the bench. Or wait to see if it heals.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #6 on: August 10, 2015, 06:14:54 PM »
I'm no carb expert, But assuming its a CB750, the stock carb has an overflow tube that exits dead nuts below the float bowl, so a leaky gasket is not an issue. When the bowl has too much fuel, it comes out that brass tube.
So you're back to the float valve. They can get worse over time and then start to leak. Or the floats themselves stick when leaned and holds the valve open, till you pull it upright again, the float unsticks and alls well again.
OCICBW
Offline jeff nelson
« Reply #7 on: August 10, 2015, 06:19:50 PM »
mine do the same and i had it looked at.i just have to remember to turn tap to off or there is petrol dripping and stinking the garage out
Offline Patrick
« Reply #8 on: August 10, 2015, 07:44:30 PM »
It's the fact that it leaks only on the sidestand that makes me think gaskets, McRider. The fuel all goes to the left side of the bowl and will always spill when the gasket is bad or misplaced. I've gone through a bunch of them - especially the cheap ones that swell when they come into contact with gas. Tilting the bike wouldn't cause the fuel to rise high enough to exceed the brass tube, but it will damn sure cover the float bowl seam. Then, when the bike stands straight up, the level goes below he seam again.
That does't mean that is the cause for the fuel to keep flowing. That is clearly the needle valve/float. But why does the float stick only when the bike is tilted? Maybe a float is slipping slightly to the side and catching the edge of a bloated gasket.
Whatever. No one will know unless he pulls the carbs.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #9 on: August 11, 2015, 05:55:31 AM »
Patrick
Got it.
They seem to stick when leaning more often, probably because of friction on the side of the pivot or bowl.
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #10 on: August 12, 2015, 09:55:19 PM »
yeah, I had the same problem... then I removed the carbs from the kickstand and attached them to the rubber manifold boots and there was no more leaking.
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline lrutt
« Reply #11 on: August 13, 2015, 09:20:26 AM »
Gonna ask where it's leaking from, overflow tubes or float bowl gaskets.
Sounds like gaskets might cure it. My K8 was similar and no matter what it would not stop until I bought a set of gaskets.
Offline Mantree
« Reply #12 on: August 16, 2015, 10:04:32 AM »
It is the overflow and is now effecting carb 4 as well as carb 1
Offline Mantree
« Reply #13 on: August 16, 2015, 10:24:24 AM »
I forgot to mention that it would drip a little before but it sat all winter with no gas in it and now it is a steady stream
« Reply #14 on: August 16, 2015, 11:09:42 AM »
Is this a 750k0-K6 or F0 with #7A carbs?
If so, the sharp edges of the float arm can raise burrs on the posts that then make the floats stick slightly open when on the sidestand (see my book, Carbs chapter, for pix and details?).
But...if they also leak with the petcock OFF, then the petcock seal needs to be replaced, too.
Offline Mantree
« Reply #15 on: August 16, 2015, 12:20:51 PM »
I will defiantly check out your book as for the petcock I am thinking of replacing it with one that will point to the back I don't know what this one came off of but it is not the original and was never meant to be on the left side of the tank
Offline eigenvector
« Reply #16 on: August 16, 2015, 01:20:17 PM »
I was going to suggest that you might just have your fuel level a bit too high in the bowl.  That can cause a leak when it's on its sidestand but not upright.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline Mantree
« Reply #17 on: August 31, 2015, 01:15:38 PM »
Can anyone identify what the parts are from
