Author Topic: '75 CB750F0 064A NEEDLE POSITION-DIFFERING ANSWERS  (Read 4469 times)
Offline jonda500
Re: '75 CB750F0 064A NEEDLE POSITION-DIFFERING ANSWERS
« Reply #25 on: August 12, 2015, 02:24:57 AM »
Frank - 4th position is from the tip of the needle. One notch below th highest groove on the needle.
so to be clear... looking at the carbs right way up, the needle clip slots are numbered 1 to 5 with the bottom slot being #1 and the top slot #5? (I always thought they were numbered 1 to 5 starting at the top!??)
A starter clutch thread:
Offline calj737
  • I refuse...
« Reply #26 on: August 12, 2015, 04:21:38 AM »
so to be clear... looking at the carbs right way up, the needle clip slots are numbered 1 to 5 with the bottom slot being #1 and the top slot #5? Correct
Offline Buttmask
« Reply #27 on: August 12, 2015, 07:24:40 AM »
I thought it was the other way around. Have always gone by this which has been posted here many a time.
« Reply #28 on: August 12, 2015, 08:49:37 AM »
I think this is where half the the problem comes in.... You hold it by the big windows to re and re them, not sure why anyone would mention the tip.
 Then a chart gets posted without specifying from which end..
So to be clear please mention which end you count from..
