Author Topic: Need some carb help -- WITH VIDEO  (Read 3477 times)
Offline mrfish2
  • I might be a
« on: August 10, 2015, 06:35:55 PM »
Okay so lets get some basics out of the way:
1976 CB550K
087A carbs
MotoGP Werks exhaust
single K&N filter in place of stock airbox
115 mains
needle clip in 4th position from the top (stock setting)
#38 pilots (from JetsRUs, so good quality)
Air screws 1.5 turns out
Floats are brand new OEM Honda, all set to roughly 22 mm, +- .5 mm
Float seats/needles are Keyster brand, also brand new
I'm having a terrible time trying to get my bike dialed in. After a friend helped vacuum sync the carbs it'll idle fairly well, but after revving it up it takes FOREVER to come back down to idle. It also blows black smoke out on the initial rev up, leading me to believe that the needle clip is a little rich. I can't for the life of me figure out why the revs would hang up so much. Yes, i've checked for vacuum leaks around the carb boots, there are none. The throttle cables are not binding up, after letting go of the throttle everything snaps back as it should and the slides are not sticking either from what I can tell.
And here's the video of my predicament, this was after warming the bike up to operating temp
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline goldarrow
  • one day, i'll be an
Re: Need some carb help -- WITH VIDEO
« Reply #1 on: August 10, 2015, 06:39:38 PM »
No airbox?
Try 105 mains for exhaust changes, 40 slow jets for no airbox.
CB550 K0
Offline harisuluv
« Reply #2 on: August 10, 2015, 06:45:37 PM »
Hanging RPMS are a very common issue.  There are multiple causes.  One cause is a lean condition.  You said you have black (rich) smoke at low RPM, so you would think this would conflict with being lean.  However, remember that you can be lean AND rich at the same time, at different ranges.
Plugs will tell you the story.  However, I am willing to bet that being at stock needle clip is not going to do it with that setup.  You have the stock airbox on but if I remember it's not going to function anything like the stock airbox anymore with the single big K&N filter mod.  Probably more like pods.
If you're rich at the low range, you might want to adjust your mixture screws out 1/8-1/4 turn at a time and see if that improves at the low end.
Offline mrfish2
  • I might be a
« Reply #3 on: August 10, 2015, 07:04:59 PM »
For visual reference here is the air intake setup I have
This was a WOT plug chop with 105 mains
And another WOT chop with 110s
Thus why I settled with the 115s.
I figured I might have to adjust the needle clip to the middle position, I'll try and find the time to do that tomorrow (between mowing 2 yards).
1980 CB650C - Sold
Offline harisuluv
« Reply #4 on: August 10, 2015, 07:09:24 PM »
Stock is 4th from the top, so moving it to the 3rd (middle) would actually lowering the needle making it even leaner.  You want to lower the clip hence raising the needle (5th position).
Offline mrfish2
  • I might be a
« Reply #5 on: August 10, 2015, 07:12:57 PM »
Ohhhh, okay I understand now. All this adjusting over the past few days has gotten me so backwards haha
1980 CB650C - Sold
Offline mrfish2
  • I might be a
« Reply #6 on: August 12, 2015, 03:49:54 PM »
Changed the needle clip to the 5th position and it was literally the same, nothing changed at all. I probably need to vacuum sync them again since taking the slides out.
« Last Edit: August 12, 2015, 03:54:25 PM by mrfish2 »
1980 CB650C - Sold
« Reply #7 on: August 12, 2015, 03:55:18 PM »
then you are still lean at WOT
order 120's, leave the needle clip where it is.
Offline mrfish2
  • I might be a
« Reply #8 on: August 12, 2015, 03:56:44 PM »
I figured that might be the next thing to do, thanks Fly. I'll get those ordered and changed out and report back.
1980 CB650C - Sold
Offline mrfish2
  • I might be a
« Reply #9 on: August 15, 2015, 12:39:13 PM »
Put the 120s in, no change still. And it still stumbles pretty bad coming off the line. And it's blowing even more smoke out when I rev it up. I'm getting extremely frustrated by this thing.
1980 CB650C - Sold
Offline goldarrow
« Reply #10 on: August 15, 2015, 01:13:58 PM »
Sounds super rich
CB550 K0
Offline mrfish2
  • I might be a
« Reply #11 on: August 15, 2015, 03:50:02 PM »
I'm considering going back to the stock airbox with a Uni foam filter and starting over, at least it'll be easier to tune.
Edit: definitely super rich now, rode around town never getting above 5k and it fouled 2 plugs
« Last Edit: August 15, 2015, 05:33:47 PM by mrfish2 »
1980 CB650C - Sold
Offline chewbacca5000
  • I polish covers!
« Reply #12 on: August 15, 2015, 05:32:54 PM »
Most of the time when this happens to me it is my throttle cables are worn out, need adjusting, lube, or replacement.  Try rolling the throttle forward to get it to "calm down" and report back.
Offline mrfish2
  • I might be a
« Reply #13 on: August 15, 2015, 05:35:49 PM »
Well Chewy, i would definitely try that given old cables, but both of my cables are brand new, less than 40 miles on the pull cable, and they are definitely properly adjusted. Rolling back on them doesn't affect it at all.
1980 CB650C - Sold
Offline goldarrow
« Reply #14 on: August 15, 2015, 05:42:18 PM »
I would start at 38 and 105
CB550 K0
  • I polish covers!
« Reply #15 on: August 15, 2015, 05:52:15 PM »
Unless you know someone who has had success with a single large pod I would go back to the stock setup for carb setting and air box.
Air leaks can be hard to find.  Could be an exhaust leak as well.
Offline mrfish2
  • I might be a
« Reply #16 on: August 15, 2015, 05:58:01 PM »
Through all the searching I've done on this forum and others I haven't been able to find anybody running the same setup as me, that's kinda why I wanted to work it out so I could say I had something unique.
Yeah, tomorrow I'm just gonna put the stock airbox back on, go back to the 4th needle clip, and try the 105 mains. That configuration seems to work best from what others have reported.
1980 CB650C - Sold
« Reply #17 on: August 15, 2015, 09:14:58 PM »
Understand that the 120s are only for 2/3-WOT positions.
They will have zero effect on idle, or off the line performance ::)
You need pilot jet and mixture screw adjustments for that...but befpre you can make those changes, you have to get jetting for WOT and 2/3 throttle(main jet and needle clip) done first.
Leave the 120's in.
« Reply #18 on: August 15, 2015, 09:18:08 PM »
Your whole setup is lean.
120main
40pilot
Needle in the 4th from the top.
Offline harisuluv
« Reply #19 on: August 15, 2015, 09:18:16 PM »
That K&N basically just takes up the same amount of space as the stock setup.  Is unable to even be seen, and a doesn't even get maxed airflow tucked in there, basically surrounded.  I guess it's unique but only you would know about it.
Offline goldarrow
« Reply #20 on: August 15, 2015, 10:07:44 PM »
Leave the 120's in.
The pipes he has does not call for 120 main.
CB550 K0
Offline mrfish2
  • I might be a
« Reply #21 on: August 16, 2015, 06:15:31 AM »
True, but the pipes combined with this air filter have proven otherwise. It flows a lot more air at WOT, you can see above where I did WOT plug chops with 105 and 110 main jets and it was way too lean.
1980 CB650C - Sold
Offline mrfish2
  • I might be a
« Reply #22 on: August 16, 2015, 06:17:56 AM »
120main
40pilot
I'll give that a whirl
1980 CB650C - Sold
« Reply #23 on: August 16, 2015, 06:32:16 AM »
With new or clean plugs in, let it idle under a fan first, and then check the color.
You will have to adjust your mixture screw to get a light tan color indicating a close to correct mixture.
Offline mrfish2
  • I might be a
« Reply #24 on: August 16, 2015, 10:29:06 AM »
That's another issue. Since adjusting the needle clips last time it doens't want to idle anymore, just sputter and die. I figure this is because I haven't been able to vacuum sync them yet. Still waiting on my Morgan Carbtune to come in the mail.
1980 CB650C - Sold
