Author Topic: 73 CB 500 Engine Surge  (Read 641 times)
Offline toobad
« on: August 11, 2015, 08:34:03 PM »
I have a 73 CB500 K2 which until up to this point was running perfectly.  About two weeks ago when shifting between gears, I noticed a quick surge in RPMs.  It only lasts about a 1/10Th of a second and then quits - resuming to a smooth operation.  I didn't think too much about it then but it is now occurring about once a ride.  I am thinking it is a carb issue and needs to be resync'd or maybe a piece of debris in one of the jets. Has anyone experienced this issue and what did you do to resolve?  Thanks for your assistance.
Re: 73 CB 500 Engine Surge
« Reply #1 on: August 11, 2015, 10:20:18 PM »
Have you read this? The Thoughts of Hondaman. / Dealing with the 500/550 "flat spot"
http://forums.sohc4.net/index.php/topic,7401.msg67251.html#msg67251
Offline calj737
  • I refuse...
« Reply #2 on: August 12, 2015, 04:31:20 AM »
It may also be indication of clutch slippage. Momentary peak of RPMs during gear changes is the motor spinning while not friction is present (clutch plates not engaged) despite the clutch lever being released. Suddenly, the plates stick, and the bike accelerates normally, and RPMs drop. Is it almost like you pulled in the clutch lever, but did not move the gears or release the throttle? If so, I'd suspect a thorough adjustment and inspection of your clutch cable is in order.
Offline toobad
« Reply #3 on: August 12, 2015, 02:02:00 PM »
Good point!  I will check it out.  Thanks for your comment.
