Author Topic: What do you put under your bike?  (Read 4262 times)
Offline jeremyillingworth
« on: August 12, 2015, 08:36:39 PM »
I have a red commercial door mat that I think I found in the house when I bought it. It catches the little drips and keeps the concrete looking less stained.
I'm looking for a second one to keep inside but I thought I would see what you guys use and if I might like it better.
jeremy
Re: What do you put under your bike?
« Reply #1 on: August 12, 2015, 08:44:36 PM »
Concrete!
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: August 12, 2015, 08:46:18 PM »
Grass
Shade tree tech
Offline Desert-SOHC
  • It's old
« Reply #3 on: August 12, 2015, 08:51:30 PM »
Asphalt driveway.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Powderman
« Reply #4 on: August 12, 2015, 10:17:09 PM »
A large pool of oil. ::)
Offline flatlander
« Reply #5 on: August 12, 2015, 10:38:22 PM »
concrete!
Offline goldarrow
  • one day, i'll be an
« Reply #6 on: August 12, 2015, 10:53:14 PM »
Drips? These bikes don't drip.  I hate doing oil change, especially the 750s, usually good qt. of oil drains on to the square bricks floor
CB550 K0
« Reply #7 on: August 13, 2015, 03:04:48 AM »
Old floor rugs and cardboard. Have some thick neoprene mats for the knees. Will say a dropped bolt or little part moves around less when dropped on a rug ;)  Might sometimes spot a little cup of whiskey, coke and ice also  :o
« Last Edit: August 13, 2015, 03:41:09 AM by ekpent »
Offline 540nova
« Reply #8 on: August 13, 2015, 04:02:41 AM »
They have these new things called oil pans. Check them out.
« Reply #9 on: August 13, 2015, 04:14:43 AM »
Cardboard if anything.
« Reply #10 on: August 13, 2015, 06:21:40 AM »
I installed ceramic tile in my garage, the oil drips wipe right up.
« Reply #11 on: August 13, 2015, 06:54:11 AM »
carpet scraps...
Offline WhyNot2
  • I'm finally an
« Reply #12 on: August 13, 2015, 07:20:09 AM »
Nothing, mine don't drip.
« Reply #13 on: August 13, 2015, 07:31:02 AM »
and you NEVER spill  ;D
« Reply #14 on: August 13, 2015, 07:44:33 AM »
Ha, I would like to see that.  Or changing oil filter.  ;D
Offline WhyNot2
  • I'm finally an
« Reply #15 on: August 13, 2015, 08:07:44 AM »
The question didn't specify when do you put stuff under it.
In that case, when changing the oil and filter, I do spread out a bunch of oil dry on the floor.
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #16 on: August 13, 2015, 09:03:45 AM »
OK, so the obvious question is.........................
If you were riding instead of being parked, you wouldn't have to worry about leaks.
So why is it parked for long enough to even consider leaks?  :)
Or, are you looking for something to keep the tires warm?  :)
Charlie
Offline lrutt
« Reply #17 on: August 13, 2015, 09:16:23 AM »
Nothing, oil stains on floor is a badge of honor. Means real bikes live there :)
Offline nippon
    • Classic Cycle City
« Reply #18 on: August 13, 2015, 10:56:42 AM »
Nothing, a CB engine doesn't lose oil.
nippon
« Reply #19 on: August 13, 2015, 11:41:09 AM »
Cardboard after a oil change or chain lube. Concrete after that.
Offline Scott
  • 72 CB750
« Reply #20 on: August 13, 2015, 12:54:10 PM »
I use an old rug.
Easy on the knees when checking tyres and chain
Offline Gene
  • Chat enuf you too can be a
« Reply #21 on: August 13, 2015, 01:03:00 PM »
Bricks.  If there's not a little drop of oil under the bike, that means it needs oil . . .
*1973 CB750K3 (Bow)
Offline Henning
« Reply #22 on: August 13, 2015, 01:15:40 PM »
Newspaper to catch the overspray when I lube the chain and as a bit of safety when I change the oil. The only mark this ratty old bike is leaving is from the sidestand on the cement floor.
71 or thereabouts 750 K1 - this one should have been put down
Offline PowerMax
« Reply #23 on: August 13, 2015, 02:14:53 PM »
Piece of cardboard ... but, I'm liking the old rug idea.
76 CB 550K
Offline Cougars750F0
« Reply #24 on: August 13, 2015, 02:32:38 PM »
Mirrors ;D ;D ;D
1970 Honda / Yoshimura 810 with ported head, 1968  Honda CB450 5 speed European model, 1973  Triumph Bonneville 750 twin carburetor model, 1975 Honda 750F0 Super Sport, 1977 Honda 750A
