Author Topic: What O-Rings for CB750 Carb Connecting Tube  (Read 2396 times)
Offline zeech
« on: August 16, 2015, 11:02:29 AM »
Trying to figure out what the right size o-rings are for the carb connecting tubes.
I have changed these at least 3 times and after the bike sits for a month or so and I turn the gas back on, here comes the gas flowing like wine out of the connecting tubes. I think I've been using 7x11x2 cause that's all I have. Though after doing a little reading it seems like I need 8x2, is that right?
If you know the proper size that are also fuel resistant that would help me a bunch. Thanks!
« Last Edit: August 16, 2015, 11:09:15 AM by zeech »
Re: What O-Rings for CB750 Carb Connecting Tube
« Reply #1 on: August 16, 2015, 11:06:29 AM »
Which carbs?
The K0K6/F0 carbs use 2x8mm, minimum thickness 1.9x7.9.
Offline zeech
« Reply #2 on: August 16, 2015, 11:14:29 AM »
1974 carbs 657B.
I could swear I've tried 8x2 in the past but they don't want to fit back in the carb easy.
« Reply #3 on: August 16, 2015, 11:24:28 AM »
1974 carbs 657B.
Nope, they are a tight fit! They have to be...wet them on the way in. I use spit, works great!
Offline zeech
« Reply #4 on: August 16, 2015, 11:27:40 AM »
*thumbs up* thanks HondaMan! I'll give that a go!
« Reply #5 on: August 16, 2015, 01:39:34 PM »
Look at post #6 in this thread,member Johnie has a part # from NAPA that he uses for those if you have one of them around you. http://forums.sohc4.net/index.php/topic,110462.msg1238711.html#msg1238711
