Author Topic: Frame Damage?  (Read 716 times)
Offline rundogdave
Frame Damage?
« on: August 16, 2015, 06:02:41 PM »
Ok, I'm cleaning up the lower triple tree on my basket case, and find the stem is bent at the bottom. Badly. And the lower bearing race on the stem is in 3 pieces. Obviously need another. Then I wonder what the frame looks like, and find this. Is this a repair, or is this factory welding. The steering stop weld doesn't look like the surrounding welds. Are the bearing races usually welded in like this? I've got a prefabbed hardtail ordered, and need to know if I should cancel, and start looking for another frame.
Thanks.
Re: Frame Damage?
« Reply #1 on: August 16, 2015, 06:08:21 PM »
The races are not welded on! :o Yes, look for another frame, and triple clamp as well.
Offline SOHC Digger
  • I'm not an
Re: Frame Damage?
« Reply #2 on: August 16, 2015, 06:13:30 PM »
Somebody went down hard with that frame once!
Re: Frame Damage?
« Reply #3 on: August 16, 2015, 06:48:23 PM »
+100%, new frame , that ones cooked.... :o
Offline rundogdave
Re: Frame Damage?
« Reply #4 on: August 16, 2015, 07:57:36 PM »
Balls!! Kinda thought that would be the response. A guy can hope. That being the case, will all of my 1978 stuff fit other years frames, or just '77, and '78?
Re: Frame Damage?
« Reply #5 on: August 16, 2015, 08:09:33 PM »
77 and 78 have a slightly different frame than the early K models, they have a wider chain line and therefore the top shock mount on the left side of the frame is slightly wider, the frame is also 2 inches longer at the rear... Start a thread in the parts wanted section, someone here may have one... ;)
Offline rundogdave
Re: Frame Damage?
« Reply #6 on: August 16, 2015, 08:14:02 PM »
Thanks.
Re: Frame Damage?
« Reply #7 on: August 16, 2015, 08:56:31 PM »
1978 what? 750?
Offline rundogdave
Re: Frame Damage?
« Reply #8 on: August 16, 2015, 09:00:17 PM »
750k.
Re: Frame Damage?
« Reply #9 on: August 16, 2015, 09:01:22 PM »
That's a shame.  What type of frame is that.  You should be able to swap your parts over to new donor. If it's 750, there will be some idiosyncrasies as noted by Retro.
