Author Topic: Direction and focus needed (78’ 550 Café build)  (Read 865 times)
Offline redrider736
« on: August 19, 2015, 05:58:37 PM »
Bought my 78’ CB550k over 2 yrs ago (running, but not well ) with plans to make my own Café out of her…
I have seen a bunch of threads on this site over the last 2yrs that have inspired me to go in certain directions for my build….calj737 & FunJimmy’s bikes comes to mind..
Guess I am at a point where I need some insight into what steps I need to take ….. I currently have my Top-End torn off the Engine (Engine in Frame still)
Planning to rebuild the Top end (Had ok compression when bought / at the lower end)
Planning Stage 2 Port Job
Planning to run CR 26’s
I have purchased CB650 Cam, Full-Pamco ignition, MotoGP 4 into 1 exhaust and a bunch of GSXR swap parts ect….
Just not sure or have any clue about Pistons ?? Do I need to replace ?? With what I am planning and have already bought what direction should I go ??  …. I emailed Dynoman and he is suggestion his Stage 2 Hot Street kit BUT doesn’t recommend the CR 26’s ?? Plus the kit has a few items I don’t want…
« Last Edit: August 19, 2015, 06:22:02 PM by redrider736 »
78' CB550k (Not Run'n / Basket Case Project)
77/78 cool 2 member #269
Offline Tews19
  • I am no
Re: Direction and focus needed (78’ 550 Café build)
« Reply #1 on: August 19, 2015, 06:18:51 PM »
Ive read on here the CR carbs are overplayed. If you can tune your stock carb bodies it should work as well as the CR minus the hefty price tag.
1970 Honda CB750 survivor.
