Author Topic: WTB 64mm pistons & rings 810-812 kit  (Read 1940 times)
Offline k2 sohc
« on: August 24, 2015, 01:28:36 AM »
I want to locate a set of 64mm pistons and rings set. I installed a yoshimura 810-812 kit back in the 70's as well all did. I recently had an incident with number 4 piston. I have had the barrels rehoned and now rebuilding the engine. I want to replace the old set of pistons/rings as they have plenty of miles thru them. The other 3 pistons are ok but a new set will be better
thanks alex
750 K2 had since new
BMW R90/6 outfit had since new
Triumph T140v Bonneville since new
BSA A10 Goldflash
Offline k2 sohc
Re: WTB 64mm pistons & rings 810-812 kit
« Reply #2 on: August 26, 2015, 02:34:04 AM »
thanks retro
this item has been withdrawn because he states this item is no longer available. The original barrels only needed a hone after my mishap that's why I'm chasing 64mm pistons etc again. Got a quote to rebore to 65mm to accept an 836 kit which are readily available $150.00 plus kit. still searching for the best option
thanks alex
BSA A10 Goldflash
