Author Topic: Stripped Bung  (Read 1008 times)
Offline rk
Stripped Bung
« on: August 27, 2015, 12:44:48 PM »
As the title states... I stripped my bung whil I was in a hurry. The peacock I finally found (apparently mine is a weird size) had the wrong thread pitch... And in haste I totally stripped the bung. And now it leaks...
Any ideas? Some special glue? Tap and die?
I don't have a welder... So that's not in the cards. Help!
1975 CB400F (First bike - learning lots)
- Podded
- Dyna S ignition
- Yoshima Exhaust
- bored to 473cc or 466cc... or something. Maybe someone can correct me
- #82 mains, #42 pilots
Offline calj737
  • I refuse...
Re: Stripped Bung
« Reply #1 on: August 27, 2015, 12:52:34 PM »
the petcock bung on the underside of the tank? If so, a die nut in HSS with the correct pitch will do the trick. Match it to your petcock pitch for best results. Or repair and get the proper petcock.
Re: Stripped Bung
« Reply #2 on: August 27, 2015, 01:57:04 PM »
If you can't find threads, maybe you can tap for NPT.... Not sure though.
Offline Vinhead1957
Re: Stripped Bung
« Reply #3 on: August 27, 2015, 02:17:30 PM »
Teflon tape and the correct pitched petcock. If you are careful, it may find the correct course
Re: Stripped Bung
« Reply #4 on: August 27, 2015, 02:43:54 PM »
How do you strip a steel bung with a brass nut..maybe a threadfile can fix it.
Offline przjohn
Re: Stripped Bung
« Reply #5 on: August 27, 2015, 03:19:48 PM »
I have used a small hacksaw blade on one that came back from the painter damaged. Just take your time and find the top thread that is causing the problem and correct it with the saw, easily filing out the bad thread. If you have, "Experienced" eyes like mine a magnifying glass helps. This can only be done of course if you didn't loose patience with it and force it to cross thread the other threads.
Re: Stripped Bung
« Reply #6 on: August 27, 2015, 03:23:39 PM »
 ? Hacksaw?
 Try a three corner file.. It actually fits the thread profile..
Offline przjohn
Re: Stripped Bung
« Reply #7 on: August 27, 2015, 03:35:20 PM »
? Hacksaw?
I find the small blade fits right in the valley of the thread and can follow it around. All you need to do is clear the thread, but I will try that next time, just need to get a file like that.
Offline rk
Re: Stripped Bung
« Reply #8 on: August 30, 2015, 07:00:02 PM »
I've been spending some time with it this weekend... It looks like the steel threads on the bung are okay... The Pingel nut I had on it is definitely toast though. I had tried epoxy to try and seal it but it leaked... And made a mess.
So... I guess the next question is... Anybody familiar with a 20mm fuel petcock? I've been looking a lot with no luck aside from this Pingel nut... Right size, wrong thread pitch.
- Podded
- Dyna S ignition
- Yoshima Exhaust
Re: Stripped Bung
« Reply #9 on: August 30, 2015, 07:05:57 PM »
If it's 20 x 1.5.mm the pitch is close to 16 tpi.. If you are tying to clean threads in the nut, but that one sounds too far gone
 Does nut come off.? Pingel may be able to get you a replacement.
