Author Topic: Has anybody installed 754's pingel petcock adapter yet?  (Read 774 times)
Offline brandEn
« on: August 27, 2015, 03:40:58 PM »
So a year or two ago our very own 754 machined some brass Pingel petcock adapters for 18mm tank threads on the 77-78 CB750 F models. Has anybody installed theirs yet? Got pics? and most important, what part number Pingel did you install? I am not sure which one to get.
Thanks!
And 754.... any chance your up for making an adapter to fit the 750 K model tanks with the petcock on the left side?
Re: Has anybody installed 754's pingel petcock adapter yet?
« Reply #2 on: August 27, 2015, 04:18:13 PM »
1/4 NPT IIRC.. Thatvwhat dragracer said.
Got not machines. Right now wired up,  can't make anything. Right now,, occasionally though I get some machine time at a friends shop.
Offline brandEn
« Reply #3 on: August 27, 2015, 04:40:07 PM »
Yea I know it's 1/4" NPT but there are a few different part numbers for them depending of the location of the petcock. Just wondering which one works best.
 Thanks Frank!
« Reply #4 on: August 27, 2015, 10:57:30 PM »
 It really depends where YOU WOULD LIKE your line/ lines to run.
 Do you prefer straight down, or out the side?  One line with a Tee downstream,  or duals?
 Are you running stock carbs,  Mikuni, Webers.......or something else..?
 Lots of variables which is why, Pingel has so many styles...
Offline brandEn
« Reply #5 on: September 04, 2015, 05:31:59 PM »
OK, I finally took a guess and ordered a Pingel. Fits pretty good but I had to press the lever in a bit further because it hit the cam cover. I also had to apply some Teflon tape a bit thick to get the outlet where I need it. I think the 6111-AH might work a bit better because it directs the outlet more towards the center but this 4111-AH will be just fine. One thing for sure, the reserve is WAY lower than the stock petcock.
This adapter is sweet. Now I just need one that fits my K tank... ;) ;) ;)
« Last Edit: September 04, 2015, 05:35:52 PM by brandEn »
